leisure battery
Moderator: Doone
				john787030
 - Bongonaut
leisure battery
hi all i need a new one any suggestions?
Re: leisure battery
What type/size have you got now? Generally, it's best to go for the highest capacity you can, but something like a 110A unit may be too large for your battery tray.
						Re: leisure battery
I bought mine from eurocarparts 110ah Lion for £79 which has a 3 yr warranty. Solar panel keeps it charged and I'm swapping the lights and stereo feeds over to the LB.
						Re: leisure battery
http://www.solarcampersolutions.co.uk  Solar panel solutions for campervans
						Re: leisure battery
Dodgey - do these fit the standard winter pack battery tray?
Re: leisure battery
I doubt it - I usually use deeper aftermarket trays - people generally come to me with aWillinton kit fitted, with their deeper tray, or I fit an ebay one , though you can check the measurements. Do bear in mind the battery can sit higher than you might think.
						Re: leisure battery
Cheers will do, probably go like for like with existing LB
						Re: leisure battery
Also note that battery has the terminal orientation such that to get the + to the left, they are at the front - closer to the bonnet. You'd get away with a (slightly) bigger battery if the terminals were the other way round.
						Re: leisure battery
Thanks Dave
						Re: leisure battery
The one that was in my bongo when i bought it finally gave up so just bough this 115ah one from Halfords
http://www.halfords.com/car-seats-trave ... ery-115-ah
It's a very snug fit but does go in. Got it for £72 on trade
95 2.5d 4WD AFT
						Re: leisure battery
How on earth do you manage to get nearly £60 off at Halfrauds
						Re: leisure battery
With a Halfords trade card, its not a fixed discount it depends what you buy, their own brand stuff including tools gets you the best discount. The mark up on some things is actually shocking. A pack of 2 sidelight bulbs that normally cost £2.49 you get for 49p. You can get a set of 3 own brand wiper blades for less than the price of you would pay for one.scanner wrote:How on earth do you manage to get nearly £60 off at Halfrauds
95 2.5d 4WD AFT
				Dr. Strangelove
 - Junior Bongonaut
Re: leisure battery
Has anyone used one of these - http://www.ebay.co.uk/itm/171510025319? ... EBIDX%3AIT ?
						Re: leisure battery
What I can tell you for sure is that this:
http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 4d2d78030e
works with the battery I linked.
