cmm303
Post
by cmm303 » Mon Mar 23, 2015 7:23 am
scanner wrote:... If you don't need the cold start bit,
don't think it works anyway
just disconnect that pipe and fit the pipe for the Cruise Control. No need for a "T" piece then and less chance of leaks.
that's good. Nothing else to do with cold start unit?
Chris with BertieB
scanner
Post
by scanner » Mon Mar 23, 2015 10:38 am
Not that I know of - but mine didn't have a coldstart unit fitted, the stub the tube connects to was just covered with a rubber cap.
cmm303
Post
by cmm303 » Mon Mar 23, 2015 8:20 pm
Went at it with renewed vigour this evening. Got the cold start pipe off the built in "T" in a few minutes and blocked the cold start vacuum feed at the unit itself. Connecting Cruise Control vaccum feed was then so so easy. Sailed through pre-flight tests and inaugural run. Need to sort out mounting the controller to give passenger a rest from holding it
Thanks everybody for your help and excellent advice (as always).
Chris
Chris with BertieB
Simon Jones
Post
by Simon Jones » Mon Mar 23, 2015 9:52 pm
Glad you've got it sorted. Definitely one of the best Bongo mods to make driving even easier.
This was where I initially mounted the switches:
This is the current arrangement using a modified stalk from a different Waeco model:
This is a future modification:
cmm303
Post
by cmm303 » Tue Mar 24, 2015 12:47 am
I'm going for the same position as you initially, except on the right. I like the stalk control but it checked out at nearly as much as I paid for the MS-50 kit. Laters maybe. The Mazda 6 steering wheel, if it is, brings back happy memories of my return to private car ownership!
I wonder if this thread can be renamed "first & last thoughts"!!
Chris with BertieB
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Sat May 30, 2015 4:16 pm
Simon, can you remember the wiring arrangement for the stalk please in lieu of the pad
Simon Jones
Post
by Simon Jones » Sat May 30, 2015 8:55 pm
I think I've got the colours scribbled down somewhere.
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Tue Jun 09, 2015 10:25 pm
Simon Jones wrote:Glad you've got it sorted. Definitely one of the best Bongo mods to make driving even easier.
Do you have a side view of the stalk position I think I may have popped mine too far away, it's quite close to the dash.. May be time to move it
Simon Jones
Post
by Simon Jones » Tue Jun 09, 2015 10:39 pm
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Wed Jun 10, 2015 6:19 am
Thanks Simon, I'm going to move mine, it's just a little too far away.
Thanks also for the .pdf instructions, made the whole job far quicker.
Gunbongo80
- Apprentice Bongonaut
Post
by Gunbongo80 » Tue Apr 20, 2021 3:29 pm
Hi Simon I'm trying to find your fact sheet for fitting cruise control, could you help me locate it in here please?
Many thanks Stuart
Jimbo1982
- Junior Bongonaut
Post
by Jimbo1982 » Sun Feb 27, 2022 6:07 pm
Does anyone know where I can get hold of a cruise control system compatible with the Bongo? The MS 50 and AP 60 seem to be available only from Germany/Australia for up to £500!
Apollo Motorhomes have the MS 50 for £149 but every time I try and buy it the website comes up with an error:
https://www.apollomotorhomes.com/?mcmsA ... eed%20MS50
Any help much appreciated!
Jimbo1982
- Junior Bongonaut
Post
by Jimbo1982 » Mon Feb 28, 2022 2:01 pm
Jimbo1982 wrote: Sun Feb 27, 2022 6:07 pm
Just a brief update on this: Apollo Motorhomes have been affected by flooding, which explains the website issues. Unfortunately they don't have any remaining stock of the cruise control kits but are looking to get hold of something similar from China.
Jimbo1982
- Junior Bongonaut
Post
by Jimbo1982 » Tue Mar 22, 2022 12:28 pm
Went ahead and ordered the AP60 from Australia via eBay. Going to install it this week - does anyone have a copy of Simon's installation guide? I can't find it anywhere on the members area.
Many thanks!
Post
by Doone » Tue Mar 22, 2022 7:05 pm
Simon was going to write it in 2008, I'm not sure he did.
But if you look at his posts on this search, you'll see he mentions several things that will help you.
search.php?st=0&sk=t&sd=d&sr=posts&keyw ... hor_id=936
