Rear light.
Moderator: Ian
bongoroy63
Rear light.
Post by bongoroy63 » Sun Apr 12, 2015 10:11 pm
My Bongo rear light has a crack and chip in which has been there since I bought it. Two days ago by chance I managed to get hold of a replacement unit in perfect condition. Very pleased until got home and realised the indicator lens was a different colour. Mine is clear with an orange bulb while the new one is orange lens. How easy is it to dismantle the unit as my clear lens is not broken so would like to put that in the new one?
I can, I do, I did.
the1andonly
Re: Rear light.
Post by the1andonly » Sun Apr 12, 2015 10:21 pm
Not at all easy to replace individual lenses (some would say impossible don't try it)
an alternative on cracks is
CAPT TOLLEY CREEPING CRACK CURE
ive sucessfully used it on mine
dry out before use hair dryier will do.
build up a couple of thin layers.
it will nor replace missing chunks
bongoroy63
Re: Rear light.
Post by bongoroy63 » Sun Apr 12, 2015 10:28 pm
But I've got a new light that cost me a few (not too much) quid. Looks like I'm going to have to go back to the chap and get the one for the other side to match it up. Damn, thought I had a bargain there!!!
I can, I do, I did.
Re: Rear light.
Post by Bob » Mon Apr 13, 2015 6:45 pm
Could you fix the cracked one and Flea Bay the new spare?
Anything with 'Bongo' on it seems to fetch good money. :wink:
Simon Jones
Re: Rear light.
Post by Simon Jones » Mon Apr 13, 2015 11:19 pm
If you're going the whole hog then you need the clear reflector panel too. The different colour lens in the cluster are bonded together so I'd doubt you'd get them apart cleanly enough to do a transplant.
bongoroy63
Re: Rear light.
Post by bongoroy63 » Tue Apr 14, 2015 9:19 pm
Had to bite the bullet and go back to get the other side to match it up. You're right Simon I had a go at getting it apart but to no avail. Seems daft to have to change the whole light when you could replace just the broken bit. Not very economical or environment friendly
I can, I do, I did.
helen&tony
Re: Rear light.
Post by helen&tony » Wed Apr 15, 2015 3:10 am
There are kits using coloured resin to repair plastic lights. I bought one on e-Bay, and it's been successful. It does require a bit of fiddling, but it's that good, i've not bothered to get a new unit. The crack was 5 inches or more
bongoroy63
Re: Rear light.
Post by bongoroy63 » Wed Apr 15, 2015 11:06 pm
Well, got the other light to match the first one I bought. It's never very simple are these Bongos!
Now realised the bottom of the right hand lens is clear but needs to be red as it is the fog light. I have a red bulb in it but feel the lens should be red. Has anyone coloured theirs and if so what with and how?
I can, I do, I did.
the1andonly
Re: Rear light.
Post by the1andonly » Wed Apr 15, 2015 11:29 pm
use the red bulb
many do, inc me
will look not too brilliant different on each side
Simon Jones
Re: Rear light.
Post by Simon Jones » Thu Apr 16, 2015 8:23 am
It's just the reversing light with a coloured bulb as they were never built with fog lights.
the1andonly
Re: Rear light.
Post by the1andonly » Thu Apr 16, 2015 10:51 pm
Simon
yes
and some importers used the naffest cheapest foglight and switch they could.
A little while back I asked a guy in work, did he personally import his Toyoxx
and he said how did you know it was an import
" the naff fog light"
Return to “Pimp My Bongo”
