Steel pipe replacement
Just repaired my rotten front cross member and under sealed the Bongo.
Found a badly corroded steel pipe with a T in it near the rear heater drivers side.
So any idea how much to replace?
Should I have any others replaced whilst the systems down?
Re: Steel pipe replacement
£85 from club shop: http://www.igmaynard.co.uk/bongo/mercha ... tm#Coolant
So any others I should change?
What labour cost?
What labour cost?
- helen&tony
Currently doing mine...via the Club Shop...Apparently a bit fiddly, so I've got a job on
I have a bit on at the moment so it may have to be a garage job for me
this may help. have a look at the twin gearbox steel pipes while your there, they are bolted alongside.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=58378
Just looked at that.
The T one is the worst but will have to see what it would cost to do the lot?
No intention of parting with the Bongo so has to be fixed
Although I opted to have new pipe fitted (takes time so labour cost is relevant) Adrian at japandirect usually just cuts out corroded tee section and fits a new tee piece using hose and jubilee clips to secure.Much less labour and negligible parts cost and should last well.
Well it looks like its just the one, so going to order it from Mazda this morning, its nice to see they still support older imported vehicles
- Muzorewa
Warrington Mazda will get you any part that's available, usually quickly too as they have a depot in Belgium holding most of the parts. Their parts operative knows what she's doing too
Thats who I am getting it from its only £57.18, the lady was very helpful and sent me the parts drawing and lead times, I will order it today and it will be here Thursday at 09.30Muzorewa wrote:Warrington Mazda will get you any part that's available, usually quickly too as they have a depot in Belgium holding most of the parts. Their parts operative knows what she's doing too
Used them myself,the lady I dealt with was excellent!!Muzorewa wrote:Warrington Mazda will get you any part that's available, usually quickly too as they have a depot in Belgium holding most of the parts. Their parts operative knows what she's doing too
Maybe an alternative?
http://www.ebay.co.uk/itm/18mm-HOSE-WAT ... 2685wt_966
That's the first thing I thought of, but the pipe has a couple of other rust spots and I feel for £58 its better to replace the lot as when and if I ever sell it, it would be better to have a new pipeTony x wrote:Maybe an alternative?
- helen&tony
Hiwinchman wrote:That's the first thing I thought of, but the pipe has a couple of other rust spots and I feel for £58 its better to replace the lot as when and if I ever sell it, it would be better to have a new pipeTony x wrote:Maybe an alternative?
Ditto...
My pipe is on it's way via the Club Shop
