Fuel Injection Pump
Fuel Injection Pump
Does anyone have photos/diagrams or data sheets of the fuel injection pump for 2.5Turbo Diesel Bongo?
Thank you in advance,
Pyroman
Pyroman
Fuel Injection Pump
I have had problems for a few weeks now, where she stutters when I am at lights or on the drive. Checked all filters etc, glowplugs. Eventually noticed fuel dripping from the pump area but not quite pinpointed exactly where it is from. So I thought that when I have a closer look, some photos or diagrams might help to orientate me.
pump
i have same leak i will take some photos and try and put them on but will have to be weekend as bongo with diesel specialist at moment they think pump has fault inside and they havent even noticed the leak some specialist?
leak
silvergecko put it this way over the years, i have taught my self how to fix a lot of probs with bongos , because of what you a just said, we have fixed all leaks on pumps , yes it cost to learn ? i have a spare pump will take some pics of the seals that leak,
LEAK
hi yes there is a gasket on end of pump, but is more likely to be the plates on stop valve, i am going to get my spare pump back tomorrow ,will take some pics to make it easy.
pump
think fault found
garage phoned today and said problem in fual tank. appparently tank has dent in it and feed pipe not letting enough diesel through under pressure so new tank should put it right or second hand one
- dandywarhol
Pump Photos
To have the photos would be great, I think a few of us may have exactly the same problems, I would hate to spend several hundred pounds on something I could have sorted myself.
It is great that so many of you are here to help and share your experiences, I don't think there are many vehicles with such support from fellow users.
- haydn callow
- dandywarhol
francophile1947 wrote:hcallow
Just a sink plunger from hardware shops may do the trick.
http://www.bizrate.co.uk/carrepairtools ... anels.html
leak
hi i have taken pics of pump sent them to ian ,dont no how to put them on ? if any body wants to email me for pics off pump with seals off and back on ? [email protected]. thanks
