fuel pump leak
steveandmary
fuel pump leak
Post by steveandmary » Sat May 16, 2015 7:50 pm
Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
philpdr
Re: fuel pump leak
Post by philpdr » Sat May 16, 2015 8:42 pm
Fact sheet in the members area and seals available in the club shop.
Re: fuel pump leak
Post by Northern Bongolow » Sat May 16, 2015 8:58 pm
have you tried to nip up the side seal bolts, both back side and front, sometimes this is enough.
another fix that sometimes works is run the fuel tank to nearly empty then add a tea spoon full of glycerine, available in small amounts from chemists. this can swell the seals so stop the leak. cheap fix if it works, it did for mine.
Simon Jones
Re: fuel pump leak
Post by Simon Jones » Sat May 16, 2015 9:40 pm
I've got a pair of brand new seals for £5 inc postage if they're any use to you. Not sure what the two nuts are for but they came in the same box of spares so you get those for free :)
The Great Pretender
Re: fuel pump leak
Post by The Great Pretender » Mon May 18, 2015 12:03 am
steveandmary wrote:Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
Leaking from where, sides, front or back? :wink:
To infinity and beyond
