Air bag light flashing
stuc
Post by stuc » Sun Jun 21, 2015 9:15 pm
Just started flashing today, probable cause anyone? Typical 1 week before MOT.
Only thing I was doing was I had the stereo out to check something but nothing disconnected.
Can I plug it in and knock it off?
Re: Air bag light flashing
Post by g8dhe » Sun Jun 21, 2015 9:45 pm
is it the 6 flashes ? If so that's the connection between computer and bag, often comes down to the clockspring on the steering wheel.
stuc
Post by stuc » Sun Jun 21, 2015 10:01 pm
It's flashing 7 times Geoff, off about 3 then 7 again. :?
Post by Northern Bongolow » Sun Jun 21, 2015 10:28 pm
has it twin airbags or just the wheel one.
Cab-ova pete
Post by Cab-ova pete » Sun Jun 21, 2015 10:30 pm
I had this problem in a car once and it turned out to be a wire in one of the front seats had deteriorated? This game age charged me £90 to get it off for the mot? A week later it was back on! I think he did it with some software? Anyway I got the £90 back after some serious deliberation :shock:
I sold the car eventually!
Peter
Simon Jones
Post by Simon Jones » Sun Jun 21, 2015 10:40 pm
The airbag sensor module is mounted in the space in front of the gear selector in the gap under the centre cubby hole. Perhaps you have disturbed a connection? Also try disconnecting the battery for half an hour to reset the system.
There are no airbag related wiring to seats so that's one less thing to worry about.
stuc
Post by stuc » Sun Jun 21, 2015 10:43 pm
Simon, that makes sense as I had the console off and I pulled a cable through so probably disturbed it. I'll have a look tomorrow.
NB it has twin bags, I prefer twin bags :shock:
stuc
Post by stuc » Wed Jun 24, 2015 9:11 pm
I had a look under the console and couldn't find the module, battery off did not fix it.
Light flashes 7 times, stays off for 10 secs then flashes again 7 times. It stays off until you select drive then starts flashing. I was gonna plug it in tomorrow but it has a strange OBD socket I've never seen before.
Anyone got a list of fault codes?
wonkanoby
Post by wonkanoby » Thu Jun 25, 2015 10:27 am
mikeWalsall
Post by mikeWalsall » Thu Jun 25, 2015 11:11 am
Paul knows Bongos (old LPG Imports) .. he fitted the LPG and towbar to mine ..!!
stuc
Post by stuc » Wed Jul 01, 2015 11:36 pm
Just an update, light still flashing, bought a lead to convert diagnostic port to OBD socket but the diagnostic machine doesn't seem to be able to communicate not sure if it's a dodgy lead or the port isn't supplying power, does anyone know the pins which would supply power.
Those fault codes would suggest pass side airbag at 7 flashes so I think next step is take the bags out and check sockets and wiring.
Simon Jones
Post by Simon Jones » Wed Jul 01, 2015 11:57 pm
It's not OBDII compatible so even with the adapter you may struggle to get a modern reader to talk to it. There's a pin out here: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
stuc
Post by stuc » Thu Jul 02, 2015 12:12 am
Cheers Simon, pity I didn't meet you at the weekend.
What is the best way to diagnose it then? Connect the wire and led and count the flashes or use the flashes on the airbag lamp?
I was wanting a starting point to go from there.
Simon Jones
Post by Simon Jones » Thu Jul 02, 2015 12:36 pm
I did see your van Stu, but didn't have a chance to pop over. Next year - definitely :). I'm a bit nervous of shorting out pins in the diagnostic socket so was going to make a box with a couple of switches & LEDs so there's no chance of connecting the wrong pins together.
stuc
Post by stuc » Thu Jul 02, 2015 2:12 pm
I wasn't keen on shorting pins neither.
