Cleaning the front fan / heater housing and motor.
Chatting to Ady during the Bash it turned out that he had a air fan housing in the back of the van for cleaning up and refubishing, so took the chance to get some photo's of the likely damage and process. Click the image below for the details;
Re: Cleaning the Air fan housing and motor.
That's interesting. Seems rusting is the problem? If so, what's the cause I wonder and would all Bongos have the problem. Any reports on how much improvement to motor once cleaned etc? And is it easy to get the little bleeder out? Must admit I'm treating mine as 'if it aint bust leave well alone' at present.
The water comes from overflowing the window screen gutter and by being sucked/rammed in from the air intake. The water then rusts/corrodes the internals, causing the motor to draw too much current, this then causes the thermal fuses on the resistor pack to pop and disconnect the fan on one or more speed settings. Before you repair the resistor pack, it really is necessary to clean out the motor housing, otherwise it continues for a short while and then pops again
g8dhe wrote:The water comes from overflowing the window screen gutter and by being sucked/rammed in from the air intake. The water then rusts/corrodes the internals, causing the motor to draw too much current, this then causes the thermal fuses on the resistor pack to pop and disconnect the fan on one or more speed settings. Before you repair the resistor pack, it really is necessary to clean out the motor housing, otherwise it continues for a short while and then pops again
Ah! Knew that but misread 'back of the van' in your post as this being a rear heater unit.
Did my front one in situ some years ago and hopefully been kept dry since
thanks for the great pics geoff, much easier sometimes to see whats wrong.
can one of the mods please maybe tweek the title so it includes the words front and heater and fix just to help others when they search for it later.
SortedNorthern Bongolow wrote:thanks for the great pics geoff, much easier sometimes to see whats wrong.
Re: Cleaning the front fan / heater housing and motor.
Thanks simon.
Got me curious now, where is the rear heater fan?
My front fan stopped working a few months ago and the advice on here was invaluable in stripping it out. I had nothing like shown in the above pictures but it certainly didn't turn freely. Bottom bearing was loaded with gunge and the speed control had melted.
During the strip out I found a felt 'washer' at the bottom bearing. I'm sure its a lubrication device, which I liberally soaked in oil. As its probably lasted 19 years I hope it lasts a few more
Rear fan is in the rear heater unit which is located in a void in the side panel behind the drivers seat (effectively in the same size space as the step on the passenger side). As it's away from the elements it does not tend to suffer any problems.
- mikeWalsall
I have a drivers side conversion ... but I can still turn the rear fan on/ off from the digital panel ..
Some conversions take the unit out, however we have a side conversion and it was left in position and works very well, great to switch it on from the front and cool/heat the back before arriving at a destination.
Good post Geoff, I took mine apart and no rust and generally clean. The fan didn't freely spin for 10 seconds though. I checked the spindle bearing and oiled them, bearings were good condition no rust or pitting but the fan still wouldn't free rotate for more more than a few spins with or without the brushes in.
I think I've forgotten how powerful the fans were when I first got the bongo but it doesn't seem that powerful these days. Resistor is ok as fans spped is ok on all settings
Any ideas
Any ideas
