Engine surging under load
PLegg
Post by PLegg » Wed Aug 05, 2015 5:47 pm
I am experiencing the engine surging when accelerating and when engine is under load. Overall performance seems OK and surging stops when cruising at constant or light throttle. My Bongo is a 2001 2wd diesel auto. Has anyone had a similar issue and possibly a solution?
Re: Engine surging under load
Post by Northern Bongolow » Wed Aug 05, 2015 10:32 pm
at that age it should have the variable vane turbo, take the pipes off and see if its getting full of shi*&. the carbon can start to jam the vanes when they are altering pitch. try a good italian tune up, that sometimes works.
maybe just a fuel filter /banjo filter in the pump though, have you changed or cleaned it out.
PLegg
Post by PLegg » Wed Aug 05, 2015 11:11 pm
I take it an 'Italian tune-up' is just to give it a big load of wellie ! I haven't checked the banjo filter so will have a look at that - thanks for the input.
Post by Northern Bongolow » Wed Aug 05, 2015 11:24 pm
lots of wellie. if that doesnt work try some carb cleaner inside the turbo, not while its running, as it will accelerate on it as its very flamable, it should break up the carbon.
you could also try removing the fuel pipe from the tank to the fuel filter housing and blow gently down the pipe to the tank, there is a fuel filter on the end of the pickup pipe inside the tank, these can get a little blocked up.
PLegg
Post by PLegg » Wed Aug 05, 2015 11:30 pm
Thanks - will try out those suggestions and post the results
Post by Bob » Wed Aug 05, 2015 11:33 pm
Thanks, feedback is really helpful to many.
And welcome aboard. :D
teenmal
Post by teenmal » Thu Aug 06, 2015 10:12 am
Classic signs of fuel starvation,the first thing I would do is change / clean all the filters.
PLegg
Post by PLegg » Thu Aug 06, 2015 12:52 pm
Thanks for that thought - I will be doing as you suggest and replace fuel/air filters . A cheap fix if that cures it !
