Not seen any advertised for a while but we made ours and the Factsheet on how to make it along with full size plans is here in the Members area http://www.igmaynard.co.uk/bongo/member ... oftent.pdf since writing that we have made some alterations, like adding zips in the front corners above the halfway mark to allow dropping the front section down to allow increased ventilation, also the plastic clips are a job to get and make so we have changed to using plastic A4 Binders with velcro stuck on them to go over the aluminium support for the original tent see like these;Ignis wrote:I was thinking to sleep inside the car, but it is an interesting idea about an inner tent - did not know about it. Where would one get it from please?g8dhe wrote:Consider getting an inner tent for the Bongo AFT if you intend sleeping up there in cold weather, being higher off the ground then your average tent the wind speed and air circulation is significantly higher. We have found the inner tent makes a significant difference both to the temperature but also the condensation problem, we use a fleece material details in the factsheets.
available from the likes of amazon or stationery stores, A4 slide binders.
