Removing a front door panel
Moderator: Ian
richlizard
Hi all.
Is there a thread (my search failed) or video/factsheet somewhere that explains how to remove the front door panels?
I am going to attempt to fit remote central locking but don't know where to start with removing the door panel.
I know there is a door panel removal factsheet, but that only seems to deal with the rear door.
Re: Removing a front door panel
Hello,
From memory, there's the screw in the door release handle, two screws under grey caps near hinges. Then prise the card off from bottom lifting over handle and lifts off lip at window.
02-07-1999 TinTop 2WD Oil Guzzler with Hyper Seat
richlizard
Thanks for the reply. I had done all the screws you mentioned, but everything was still so secure I didn't want to risk breaking anything by forcing it. There was also a screw inside the little 'something' holder but again the holder didn't come out.Gefail wrote:Hello,
So it is really just a case of brute force?
- Muzorewa
There's a screw in the recess where the door release handle is but only remove the screw, thread the handle through the door card as you remove it. The screw in the 'something holder' needs to come out but only the screw. Then there are a mixture of screws & poppers around the perimeter. The top is kind of perched on a lip so you need to lift it up slightly too. There's not much to remove really.
richlizard
Thanks for that. I am going in... first thing in the morning.Muzorewa wrote:There's a screw in the recess where the door release handle is but only remove the screw, thread the handle through the door card as you remove it. The screw in the 'something holder' needs to come out but only the screw. Then there are a mixture of screws & poppers around the perimeter. The top is kind of perched on a lip so you need to lift it up slightly too. There's not much to remove really.
Then be prepared to be bombarded with 'what wire goes where'. Presumably, if I have central locking then there is a live feed to connect the locks that I can feed into with my remote thing?
You don't connect electrically at all! You mount a single door motor to operate the latch, and drive that one motor from the remote Fob receiver, the drivers door lock being operated drives the existing switch to release all the other doors.
You can pickup +12 volts unswitched and earth to drive the receiver from within the door;
The Blue/Red wire is +12v unswitched on the K2-01 connector
and Black is earth from the K1-01 connector;
richlizard
I think that is what I mean Geoff.
But not sure what you mean nothing electrical? How does my actuator thingamajig work then? But then you go on to say powered by... so I guess we mean the same thing.
And yes, I know the driver's lock activates all others which is why I was asking about there being a live connection somewhere.
I will look at those drawings to see if I can make sense from it when back on PC. On small laptop now.
Appreciate the advice. Just confused why you say no electrical connection... then go on to explain how to connect electrics lol.
richlizard
If you could explain what a K1 and K2 connector is that would be great.
The only electrical connection is for power, the signal to control the central locking is purely mechanical.
The K1 and K2 connectors are the plugs and sockets are within the door and terminate the wiring looms, if you click the image it shows you the circuit and the plug details at the bottom of the page, move on to the next page and there are diagrams showing the locations of the connectors. Hence you can find the right wires to tap into for the power.
richlizard
I am going to try get the panel off now Geoff.
I was just a little confused you saying there was no electrical connection at all... then giving me electric wiring diagrams.
What about the turning lights too? They need to flash right?
Only if you want them to flash, you dont need to connect that bit if you dont want to.richlizard wrote: What about the turning lights too? They need to flash right?
Top tip when removing & working inside the door cavity, wear disposable gloves & clothes you dont mind getting dirty. The plastic membrane under the panel is stuck on with horrible black sticky stuff that is a nightmare to wash off skin & clothes. It gets everywhere.
95 2.5d 4WD AFT
richlizard
Cheers for the tip. Is it much more bother to get the indicators to flash? If so, I won't do it. But if easy, it makes sense.nth wrote:Only if you want them to flash, you dont need to connect that bit if you dont want to.richlizard wrote: What about the turning lights too? They need to flash right?
looks like the solution as described by g8dhe is contained within the door. You'd need to cable into the vehicle to pick up the indicators. Wiring behind the bulkhead is reasonably accessible so not difficult difficult but a chunk more work.richlizard wrote:Cheers for the tip. Is it much more bother to get the indicators to flash? If so, I won't do it. But if easy, it makes sense.nth wrote:Only if you want them to flash, you dont need to connect that bit if you dont want to.richlizard wrote: What about the turning lights too? They need to flash right?
Chris with BertieB
richlizard
Ok decided to give up on the lights then.
But... I... err...
Well I managed to get the panel off. I was expecting to see the door lock at the top with some kind of electronic unit under it to control the other locks.
But it seems to be one long bar to some hidden space at the bottom of the door.
Here is my little motor thing that I assume will eventually push this lock up and down? Somehow? Somewhere?
But... I... err...
The central locking module already fitted in the Bongo is behind the passenger glove box, there are just a couple of wires from the switch in the door going to it, see the first diagram.
In your remote door kit you should have the door motor (as in picture), a receiver and hopefully a couple of remote fobs!
You need to fit the door motor and a mechanical link to pull down the door lock, and then install the receiver and connect it to the new door motor and the two power connections I mentioned above. Yes trying to pick up the indicator lights for signalling that it has worked is a pain as you would need to add additional wires to the door loom.
