One thinks one knows what this means. Right?
thanks so much for the offer. I have a couple of local contacts to follow first. Manifold is warped. Stud 8 broke as I was removing the manifold.I'll check the others.Northern Bongolow wrote:this may have some info in it like what studs to get etc.
i have 2 machined manifolds if your stuck for one.
i found splitting the turbo the best easiest option myself, i reused all the metal gaskets apart from the head to manifold gasket, fit all new studs if you want to be sure as i found the other end (pot 4 ) was stretching too, you can just see it in the pics in the link below.
if you split the turbo as below you can leave both the oil pipes and the coolant system intact, but your already drained so i wont affect you.
http://www.igmaynard.co.uk/bongo/forum/ ... ud#p418217.
top tip. one of the turbo mounting bolts is a real barsteward to get off as its mounted from the inside,
