Sliding door contact pins seal
Gefail
Post by Gefail » Thu Apr 21, 2016 10:33 am
Hello,
I'm trying to replace the perished seal that surrounds the sliding door pin contacts, which is currently held together with vaseline. Done a search here and on Lush projects, but seems elusive. Much appreciate a nudge in the right direction. Thanks, David.
02-07-1999 TinTop 2WD Oil Guzzler with Hyper Seat :shock:
Re: Sliding door contact pins seal
Post by g8dhe » Thu Apr 21, 2016 10:47 am
Mine looks a bit rubbish and I had planned to stick several layers of foam material together (mouse mat type foam) however it hasn't deteriorated any further so never got round to doing it.
wonkanoby
Post by wonkanoby » Thu Apr 21, 2016 11:45 am
[email protected]
email george
helen&tony
Post by helen&tony » Thu Apr 21, 2016 12:59 pm
Try back-packing roll-mattress, it cuts very nicely!
Gefail
Post by Gefail » Thu Apr 21, 2016 6:41 pm
Thanks for the replies, it looks just like that photo. I'll email George see if theres any replacements in better nick!
BongoBongo123
Post by BongoBongo123 » Thu Apr 21, 2016 6:52 pm
I have often wondered if it would be possible to cut one of these out of a flip flop with a craft knife and super glue it on. Ours is quite bad but I used that Gummi Plege (rubber conditioner) and it holding in tact at the moment. I daub a bit on every time I remember to seems to soften it up a bit and stops bits flaking off.
Finding a new one would clearly be a nicer solution, good luck with the hunt.
They call me light foot.
Post by g8dhe » Thu Apr 21, 2016 10:31 pm
That photo was taken about 8 years ago now! Its been the same ever since, and still looks identical I have no worries about it doing its job either! Its just that the looks of the foam make you think its about to fall too pieces!
Post by Bob » Thu Apr 21, 2016 10:43 pm
Could be a picture of ours.
dobby
Post by dobby » Thu Apr 21, 2016 10:49 pm
Mines the same, on a different note my side door makes the soft close whirring noise when I go round bends :shock: I've cleaned up the contacts etc need to see if that solves it
Simon Jones
Post by Simon Jones » Thu Apr 21, 2016 11:15 pm
I think the switch that determines if it's closed is in the latch mechanism at the rear of the door which is tricky to get to. You could try cleaning the metal contacts as it can't hurt.
dobby
Post by dobby » Fri Apr 22, 2016 5:30 pm
Simon Jones wrote:I think the switch that determines if it's closed is in the latch mechanism at the rear of the door which is tricky to get to. You could try cleaning the metal contacts as it can't hurt.
Cheers Simon, I've done the forward ones but didn't know about a rear one do I'll do that over the weekend. I think I've fixed it already but worth doing
Gefail
Post by Gefail » Fri Apr 22, 2016 11:14 pm
As expected, George at Bongo Spares only has ones in similar condition.
Time to see what can be substituted...
Post by mikeonb4c » Fri Apr 22, 2016 11:57 pm
I took mouse mat neoprene foam type rubber and cut to outline with modelling knife after removing mat surface. Contact glued two layers of that with evostick then contact hlued the lot in place. That was 8 years ago and its bern perfect ever since - no moisture or corrosion on my contact pins and looks 100% smart. Quick job too.
Gefail
Post by Gefail » Sat Apr 23, 2016 11:34 pm
Sounds good mikeonb4c got a photo?
Belated birthday greetings, hope it was a good one! \:D/
Post by mikeonb4c » Sat Apr 23, 2016 11:47 pm
Gefail wrote:Sounds good mikeonb4c got a photo?
Cheers matey, had a great day, in a 64 year old kind of way ha ha. Doing this on my phone but hopefully this link will show a pic when you click:
http://s185.photobucket.com/user/mikeon ... sort=3&o=0
