Siezed bongo?
TonyBongo
Siezed bongo?
Post by TonyBongo » Sat Apr 30, 2016 5:51 pm
Hi guys,
My bongo has been in my garage unused for 6 years while I've been busy having three kids.
Unsurprisingly, it won't start although the (new) battery is fine and the starter and solenoid are ok (bench tested).
I think the engine or something is seized as nothing turns when I try to start - just clicking from the starter solenoid.
Any advice on what I could try doing to unseized it or diagnose the problem?
Ta
Plan B is a new engine.
nth
Re: Siezed bongo?
Post by nth » Sat Apr 30, 2016 6:22 pm
Have you tried turning the engine over by hand with a spanner on the crankpulley ? If it wont turn take the drive belts off in case the alternator or A/C compressor is seized.
95 2.5d 4WD AFT
TonyBongo
Re: Siezed bongo?
Post by TonyBongo » Sat Apr 30, 2016 7:15 pm
Thanks nth
I haven't tried that as it isn't very accessible (can just about reach it by hand but obviously not able to put any force on it).
Will removing the top panel (to which the gear stick and hand brake are connected) give adequate access?
Tony
TonyBongo
Re: Siezed bongo?
Post by TonyBongo » Sat Apr 30, 2016 7:19 pm
By top panel I mean the metal body covering the engine - not simply the plastic bit which I've obviously already removed!
nth
Re: Siezed bongo?
Post by nth » Sat Apr 30, 2016 7:32 pm
might be easier access from underneath. on the off chance its a manual you could rock it in gear
95 2.5d 4WD AFT
Re: Siezed bongo?
Post by mikeonb4c » Sat Apr 30, 2016 8:04 pm
Could just be your starter motor - these are known to play up and a cheap repair pack is available.
TonyBongo
Re: Siezed bongo?
Post by TonyBongo » Sat Apr 30, 2016 8:25 pm
Thanks Mike,
I bench tested the starter and solenoid and all seemed fine.
Is that a K6?
Tony
Re: Siezed bongo?
Post by mikeonb4c » Sat Apr 30, 2016 9:31 pm
TonyBongo wrote:Thanks Mike,
Is that a K6?
Tony
Apologies, replied in a hurry while watching tv :oops:
Ha ha yes its. Ka6CR that i had a share in many years back. Lovely little plane that i took on a couple of 100k xc flights. Happy days.
Engine situation is interesting. I'll be interested to see how it goes. Hard to believe engine might have to be written off. [-o<
maxi_77
Re: Siezed bongo?
Post by maxi_77 » Sun May 01, 2016 4:50 pm
If the engine was seized I would expect there to be some sound from the starter itself, trying to turn. You could monitor the battery voltage as you try as although the starter solenoid works on the bench with no load it may well fail under high currents required to turn the engine. You could try shorting the solenoid out and see if the engine turns. Changing the solenoid contacts is easy and cheap.
White diesel Bongo
TonyBongo
Re: Siezed bongo?
Post by TonyBongo » Sun May 01, 2016 5:08 pm
Pleased to report that the engine isn't siezed. Jiggled the flywheel via screwdriver in bell case inspection hole. flywheel turning as I try to start engine, but it's not picking up.
Not sure whether I need to bleed the fuel pump/injectors? I tried depressing the manual pump on top of the fuel filter a few dozen times.
Any suggestions?
Re: Siezed bongo?
Post by Northern Bongolow » Sun May 01, 2016 5:30 pm
if its 6 year old fuel i would try running it on a fuel can supply direct into the pump, with some fuel pump/injector cleaner in it, then crack the injector pipes etc.
the old fuel maybe a little cheeeeeeeeeesey.
TonyBongo
Re: Siezed bongo?
Post by TonyBongo » Sun May 01, 2016 5:53 pm
Thanks. Good advice.
BP suggests diesel lasts 6-12 months before gumming up so after 6 years it's probably.....past its best!
Just got to figure out how to do it now! By 'cracking injector pipes' do you mean removing injectors?
Tony
Re: Siezed bongo?
Post by Bob » Sun May 01, 2016 6:31 pm
Just loosening them should do it, crank engine then tighten as fuel comes out. :)
Re: Siezed bongo?
Post by mikeonb4c » Sun May 01, 2016 6:44 pm
As a one off, might it be acceptable to use that quick start stuff you spray in the air intake?
helen&tony
Re: Siezed bongo?
Post by helen&tony » Mon May 02, 2016 4:09 am
If t hasn't run for that long, you DEFINITELY need to drain the fuel, empty all the fuel lines / filters and start with fresh juice...Depending on fuel quality to start with, it CAN deteriorate in 6- 9 months...you might get a wee bit more, but 6 years it's DEFINITELY naff....as Ady says ....CHEESY
