Cool - that's eliminated that then. Be interesting to see if the problem stays away or returns. Is the fuel pump original / never been overhauled?al & chris wrote:Started up straight away, no lumpiness or rough running. Don't think it's its the battery, it's not new but it terns engin over wellmikeonb4c wrote:Great news it started ok. Did it run lumpy at all immediately after starting? How old is the battery?
Won't start
Re: Won't start
Re: Won't start
did you get good voltage when you tested it. could you not test at the plug/supply.
heres some good pics from an old ebay listing, it looks easy from the pics and it isnt that bad really.
http://www.ebay.co.uk/itm/mazda-bongo-2 ... 1378475851
al & chris
- Tribal Elder
Re: Won't start
Am I looking at right thing? On second picture looking from back of pump. Multi plug on top following black wire down to fuel cut off valve back right hand side from that view. All injector pipes make it so difficult to access from front when fitted.Northern Bongolow wrote:did you get good voltage when you tested it. could you not test at the plug/supply.
Re: Won't start
yep thats the baby.
al & chris
- Tribal Elder
Re: Won't start
Well just done 250 miles this weekend with lots of stops and starts and no problems. Was half expecting a no start at some stage.
What was it? Could it have been a fuel blockage? Just hope it's gone for good. Thanks all for suggestions and advice.
Re: Won't start
Great news and fingers crossed it stays that wayal & chris wrote:Well just done 250 miles this weekend with lots of stops and starts and no problems. Was half expecting a no start at some stage.
