2 stroke oil
Moderator: Doone
- haydn callow
2 stroke oil
Did a bit of research on tinternet.....200 ml of low ash 2 stroke oil per 50 Liters of diesel. I now get a xtra 2mpg....quieter engine especially when cold and smoooooooth running......now admittedly I'm driving a more modern vehicle but it could be worth a try in the oil burning Bongo.
If anyone try's it, please give feedback.
5 lts of oil @ £17
Also lubes the fuel pump.
5 lts of oil @ £17
Re: 2 stroke oil
Sounds interesting and thanks for the heads up. Might try it.
- haydn callow
Re: 2 stroke oil
And if your runnng with a DPF the recycling periods will be greatly extended. ( not applicable to Bongos )
Re: 2 stroke oil
That's a thought.
- the1andonly
- Tribal Elder
Re: 2 stroke oil
I used 2t in 2 VAg 1.9 TDi and the Bongo (30-50% rape oil) for 2015 with no discernable difference
http://igmaynard.co.uk/bongo/forum/view ... ke#p648928
been on straight diesel since price went down
- haydn callow
Re: 2 stroke oil
Don't understand your post!!the1andonly wrote:I used 2t in 2 VAg 1.9 TDi and the Bongo (30-50% rape oil) for 2015 with no discernable difference
- the1andonly
- Tribal Elder
Re: 2 stroke oil
the1andonly wrote:I used 2t in 2 VAg 1.9 TDi and the Bongo (30-50% rape oil) durring 2015. No discernable difference in fuel comsumption or running was observed.
The Bongo been on straight diesel since sept 2015
Hope a few extra words helps
Re: 2 stroke oil
Should I add 2 Stroke Oil to my diesel to improve its lubricity?the1andonly wrote:the1andonly wrote:I used 2t in 2 VAg 1.9 TDi and the Bongo (30-50% rape oil) durring 2015. No discernable difference in fuel comsumption or running was observed.
In short, you shouldn't. 2 Stroke Oil is designed for 2 stroke motorcycle engines, not 4 stroke vehicles. Vehicle manufacturers and fuel refining companies all agree that running 2 Stroke Oil in fuel is likely to cause complications and there have been reports of engine failures due to 2 Stroke Oil sludging up valves and fouling injectors. As fuel refineries have produced lower sulphur diesel, so too have they added lubrication substitutes to the new diesels to the point that lubrication is now even higher than that of high sulphur diesel.
The vehicle manufacturers don't recommend putting 2 Stroke Oil in your diesel...
The fuel companies don't recommend putting 2 Stroke Oil in your diesel...
The 2 Stroke Oil manufacturers don't recommend putting 2 Stroke Oil in your diesel,
therefore it is a simple deduction that there is no reason to add 2 Stroke Oil to your diesel!
Re: 2 stroke oil
I wouldn't claim to know either way about the wisdom of using 2 stroke oil. Haydn strikes me as someone who reads a lot around something before deciding to experiment. Rita's comments read very much like those by Nigel Worc's in 2014 on http://www.pistonheads.com/gassing/topi ... 55753&i=60.
On that forum, one wag counters the argument by referring to this interesting piece (which seems to suggest additives can be effective):
http://www.dieselplace.com/forum/76-spe ... ?_k=bue29u
So, I guess yer pays yer money etc.
One question i would have is whether, if there are issues linked to use of 2 stroke oil, there could be similar issues linked to using vegetable oil as fuel, since fuel companies don't (as far as i know) recomnend that either.
- the1andonly
- Tribal Elder
Re: 2 stroke oil
please read both
http://www.carmag.co.za/technical_post/two-stroke-oil/
http://www.fuelexpert.co.za/2-stroke-oi ... -study.php
then remember which company he works for.
read the details and don't accept the truth
unless it is the truth
but John how do i know its the truth?
Re: 2 stroke oil
Phew, you could go nuts trying to get at the truth! One thing i always felt when running 20% veg oil was that the engine sounded and felt a little smoother, and i was never quite sure why that was.
Re: 2 stroke oil
I agree with you there ^^^^mikeonb4c wrote:Phew, you could go nuts trying to get at the truth! One thing i always felt when running 20% veg oil was that the engine sounded and felt a little smoother, and i was never quite sure why that was.
I always thought my LANDROVER had a better performance when on 50/50 veg oil and diesel
And my bongo seemend to run better
I don't bother now days not a lot of difference in price
And carnt be bothered fetching in getting rid of bottles
As for if it and 2 stroke etc is better for your engines I bet it is
We get fed the results they want us to see
by putting the money into the tests they want to do
to get the results they want
To make themselves the most money
Re: 2 stroke oil
Could one reason for an engine sounding quieter be that there is less of an explosion taking place and consequently there will be less power developed?
I'm one who always imagines that the Bongo seems quieter and smoother on veg oil but having tried to move on from the antique measurements called miles and gallons, I've never checked the true performance.
I get enough satisfaction from partially beating the system by using as much veg oil as will let me start smoothly.
Frank
Frank
They flew, I took up naturism
- BongoBongo123
Re: 2 stroke oil
Or a thick layer of carbon and burnt grease on your valve stems etc. Like a greasy carbon cushion.
I dunno just having a laugh, and my word do we need a laugh... I was told that vag oil is a bad plan for regular use in the Bongo despite the fact it can be done.
All the extra stuff you have to check, filters etc. hardly seems worth it and why risk the damage for a few bob.
They call me light foot.
Re: 2 stroke oil
BongoBongo123 wrote:Or a thick layer of carbon and burnt grease on your valve stems etc. Like a greasy carbon cushion.
