HT Leads for Late 2 Litre Bongos
According to Lush Projects different HT leads were introduced on 2 litre petrol Bongos which have later chassis numbers than SGEW-600021 or SGE3-500005.
As an example see here for details: http://lushprojects.com/bongopartsmk2/c ... 1of02.html and then click on 18-190 to bring up the part numbers and descriptions.
The question is, what does 020905 mean in the final column? It's not a chassis number. Is it the date of production (I don't think so.......)?
Re: HT Leads for Late 2 Litre Bongos
when was the last ones made ian, it looks like a, from date to the end of prod, last modified date, or the last manufac date.?
Anybody know what the difference is? Is the dissy cap the same?Ian wrote:According to Lush Projects different HT leads were introduced on 2 litre petrol Bongos which have later chassis numbers than SGEW-600021 or SGE3-500005.
The Distributor Cap has a different number as well, see http://lushprojects.com/bongopartsmk2/c ... 2of02.html, click on 24-310.
Again, it says the the part number change is applicable after 020905. But if this is a date, it doesn't seem right. For instance SGEW-600022 was made on 06/09/02 and SGE3-500006 was made on 15/9/02.
Although SGEWs and SGE3s were made up until December 05, it doesn't explain why 020905 is shown as a separate line on the parts catalog.
I think that the Japanese have a different year calendar from the British , IE Japanese calendar years .
You should be able to Google it.
They also have a different diet from the British, in the words of Bobby George (the darts player) If it moves or flies they eat it
Can't see flies being very tasty.
you lose weight chasin em though, so they are good for you.
as i read it ian it looks like an up to date etc there are 2 types or cable, the little line either before or after the number denotes either above this or below this date, maybe the grade of cable/insulation changed on this date.
It's not date related. Look at this page: http://lushprojects.com/bongopartsmk2/c ... 4of05.html. At the top it says that the rear seat parts are applicable up to 74-01. That can't be a date as this is the page for rear seats on 95 to 97 Bongos.
Bob wrote:Can't see flies being very tasty.
Try Mydas fly and flied rice, and a couple of months fighting in the Jungle.
