A few weeks ago, my van over heated whilst out on a sunny Sunday drive. The issue was that both of my alternator belts (which I hadn't changed as per the maintenance schedule
To cut a long story short, I purchased new belts, fitted them, had the van fully serviced and checked over, and was driving the van for about a week, when I thought I'd take a little look under the bonnet/passenger seat...
One of the (brand new) alternator belts had turned itself inside out, but was still nestled in the v-groove of the pulleys. There was some damage to this belt and due to some rubbing, had also affected the other belt. Suffice to say, I stopped using the van before one or both failed again, and am now seeking help.
I believe that the belt inverted itself because I hadn't tightened the tensioner bolt sufficiently; however, this brings me to the reason for today's post/question: I can tighten the tensioner bolt until it is virtually at the end of it's run, i.e. the alternator is pulled fully towards to the passenger-side of the van.
I had noticed this previously after changing the alternator some time ago, but since no problems were being caused, I thought nothing of it. But now, with these recent problems, I am starting to question this. Shouldn't the tensioner bolt, when fully tensioned, be more central on the 'run'?
To this end, I have just ordered two 13x1050 and two 13x1075 v-belts (instead of the standard 13x1100 belts) from eBay to see if these will fit, and allow me to tension the belts more fully, preventing them from inverting again.
Can anyone:
(a) Make sense of my rambling post?
(b) If yes, shed some light on this issue? I have searched long and hard for something similar on various forums, but with no luck.
Any advice/insight would be most welcome and greatly received.
