I thought I'd post a quick update and if you don't mind, ask for a small favour?
Since my previous posts, I have tried and failed to fit the aforementioned 1075 belts (just to see). I have since fitted some new 1100s, run the van gently, taken off, checked and refitted too many times to count, without the belts inverting, but:
- the belts were too easy to fit when new; they went on pretty easily, not at all "as if they were too small" as someone mentioned previously
- the tension bolt is pretty much at it's limit; the bolt even starts to bend if I were tighten it any more
Having checked all the pulleys, including the bottom one, and finding almost no play or wobble in any of them, the next thing I would like to check is the water pump, and more specifically, it's pulley. Could I humbly ask someone to measure the diameter of their water pump pulley, and let me know what it is?
If my pulley is smaller, this would help explain this little mystery. If it isn't, then I might well end up with a permanent bald patch on one side of my head....
