half shaft
davepickering
half shaft
Post by davepickering » Sat Jul 29, 2017 12:57 pm
hi dose anyone have ideas why my rear half shaft is moving out of the axle and making the disc rub on the caliper ?
rita
Re: half shaft
Post by rita » Sat Jul 29, 2017 1:38 pm
do you mean, the brake disk is rubbing on the brake pad?
Good Luck.
davepickering
Re: half shaft
Post by davepickering » Sat Jul 29, 2017 4:54 pm
half shaft is moving in and out of axle and pushing the brake disc against the outer arm of the calliper .
just taken the wheel and Caliper and disc off, and I can move the half shaft in and out the axle about a good 1/2"
rita
Re: half shaft
Post by rita » Sat Jul 29, 2017 6:13 pm
Sounds like a bearing and or back plate problem , you need to investigate a wee bit further, its not advisable to drive the vehicle in this condition.
Good Luck.
davepickering
Re: half shaft
Post by davepickering » Sat Jul 29, 2017 9:10 pm
rita wrote:Sounds like a bearing and or back plate problem , you need to investigate a wee bit further, its not advisable to drive the vehicle in this condition.
Good Luck.
Thanks Rita
off road at the moment when its not raining will draw out half shaft and have a good look see if it needs replacing
rita
Re: half shaft
Post by rita » Mon Aug 21, 2017 3:33 pm
Has it stopped raining.
:lol:
davepickering
Re: half shaft
Post by davepickering » Tue Aug 22, 2017 10:28 pm
sorry been sorting out for mot (passed no advisory's) new bearing had fallen apart so got halfshaft with bearing on replaced unit all good now just waiting for painting now had new arches fitted, sills and inner sills welded :o
Re: half shaft
Post by Bob » Tue Aug 22, 2017 10:43 pm
Well done. :)
davepickering
Re: half shaft
Post by davepickering » Sat Nov 11, 2017 2:23 pm
all the paint work done now just got to sort heater matrix :(
