Repair panels
fordmill
Repair panels
Post by fordmill » Wed Mar 21, 2018 10:12 pm
Good evening bongoers,
Just dealing with the dreaded rear wheel arches on my 95 Freda, Can anyone give me advice on where's the best place to purchase rear wheel arch repair panels?
Fordmill
Billybongo123
Re: Repair panels
Post by Billybongo123 » Wed Mar 21, 2018 10:58 pm
I bought a set off eBay, seem pretty good
We love our rusty Bongo "Billy", despite his many faults!
Re: Repair panels
Post by g8dhe » Thu Mar 22, 2018 12:11 am
See this set of images here click the image for the full details, Paul Horsfall put them together (he has done a few ;-) - works at Discount Trucks);
Billybongo123
Re: Repair panels
Post by Billybongo123 » Thu Mar 22, 2018 8:10 am
They look the same as the panels I bought. I will let you how I get on in a few weeks. Used to welding up old Hondas, which are paper thin, so I'll manage.
Re: Repair panels
Post by mikeonb4c » Thu Mar 22, 2018 11:08 am
I recall being told that the arches need an insert section welding in at their apex if they are to match the circumference of the original (and thus match up to / line up with the bumper). No doubt you're onto that but i mention it in case.
Re: Repair panels
Post by g8dhe » Thu Mar 22, 2018 1:06 pm
This is an animation showing the alignment - the wheel hub is used as reference and the two images show the before and fitted positions;
teenmal
Re: Repair panels
Post by teenmal » Thu Mar 22, 2018 1:24 pm
mikeonb4c wrote: Thu Mar 22, 2018 11:08 am I recall being told that the arches need an insert section welding in at their apex if they are to match the circumference of the original (and thus match up to / line up with the bumper). No doubt you're onto that but i mention it in case.
If you use the Merc arches it is advisable to do as you say,cut and weld in a fillet .
Take care.
Billybongo123
Re: Repair panels
Post by Billybongo123 » Thu Mar 22, 2018 7:26 pm
Nice one guys, thanks for that tip. Hopefully I don't balls it up πŸ˜‚πŸ˜‚πŸ‘Œ
teenmal
Re: Repair panels
Post by teenmal » Fri Mar 23, 2018 10:58 am
Billybongo123 wrote: Thu Mar 22, 2018 7:26 pm Nice one guys, thanks for that tip. Hopefully I don't balls it up πŸ˜‚πŸ˜‚πŸ‘Œ
Is this on the same vehicle that you paid Β£8000 a few weeks ago ?.
Take care
Billybongo123
Re: Repair panels
Post by Billybongo123 » Fri Mar 23, 2018 9:26 pm
teenmal wrote: Fri Mar 23, 2018 10:58 am
Don't be mean to me, 😩
I'm well aware we probably paid a bit more than we should but shit happens, and the insides great. Just needs a bit of love.
Take care
Bongolia
Re: Repair panels
Post by Bongolia » Sat Mar 24, 2018 2:26 am
Heres a link to how I did mine using merc arches. If you want to keep the right arch shape and keep the thickness of the dog leg at the sliding door right you need to put the insert about a third of the way up on the left portion of the arch.
I also let the panel in up behind the original quarter panel, its easier to level that way and the repair can be much tighter.
Good luck!
viewtopic.php?f=3&t=72827&hilit=bongo+4 ... 90#p685524
fordmill
Re: Repair panels
Post by fordmill » Sun Mar 25, 2018 2:45 pm
Hi folks,
So have I got this right? you can use merc wheel arches instead of mazda arches? If so what merc arches can I use ?
Re: Repair panels
Post by Doone » Sun Mar 25, 2018 3:27 pm
THIS LINK has info on Mercedes arches
Donkey0803
Re: Repair panels
Post by Donkey0803 » Wed Mar 28, 2018 10:14 pm
Hi all, I've got the dreaded arch problem...more of a problem at the base of the arch at the rear, where it meets the cill, then other side where the rear bumper meets it, looking for someone in the midlands to quote for both sides replacement and spray if anyone knows someone? Not up to this...... Thx in advance.
Re: Repair panels
Post by Bob » Wed Mar 28, 2018 10:17 pm
Ian Taylor, Stoke, can do this. :wink:
Return to β€œBongo Chat”
