I've left the fig of 8 strips attached to the roof gutter since the day I got them. I did sikaflex them into place to stop them sliding about and was also able to get silver ones to match the van so they are very unobtrusive - they're also available in white or I suppose you could paint them in the correct colour for your van after using a suitable plastic primer.Flanners wrote: Wed Apr 11, 2018 12:45 pm Given the decent fit of Fig 8 strips on the gutter of the Bongo I intend to leave mine in situ over the Summer months, it will also stop wear to paint on guttering from frequent removal and fitting (hopefully)
Figure 8 awning mounts
Re: Figure 8 awning mounts
Mark
Just put mine on and cut one of them them down to size, they are a light grey colour so match the Sunlight Silver paint-ish, off out this evening for an overnight wild camp will see how the awning gets on. I am reluctant to glue the Fig 8's on at the moment see how much they move about.
- Billybongo123
I tried mine today, they slide a bit so I might have to bond on. Let me know how you get on, have fun. We are off camping tomorrow night at a pub. Ideal.Flanners wrote: Fri Apr 20, 2018 9:49 am Just put mine on and cut one of them them down to size, they are a light grey colour so match the Sunlight Silver paint-ish, off out this evening for an overnight wild camp will see how the awning gets on. I am reluctant to glue the Fig 8's on at the moment see how much they move about.
We love our rusty Bongo "Billy", despite his many faults!
If you experiment with the front and rear fig of 8 strips you can work out where they stop moving around - push the front one forwards so it starts to bend into the n/s screen gutter and the rear one towards the rear of the van until it stops due to the curvature of the gutter. Measure the distance between them - cut the middle strip to this dimension and it will clamp the outer two in place with minimal movement. A dollop of Sikaflex on the joins will keep everything in place if you're extra-picky!!
I've not had any problems with the awning becoming detached or the fig of 8 strips moving since I attached them to the van in this way!
Mark
- Bongo Brain
- Bongonaut
Last weekend, I used the Kador strip in between my van & my awning
I was pleasantly surprised at how easy it was to detach the van from the awning - so I could drive away
I left the set of fig 8 strips on the rain gutter, and it didn't detach while driving around
I'd definitely recommend using the Kador strip - although one night it was particularly windy, and the second set of fig 8 strip and Kador strip slid in the high winds a bit too easily. I must think of a way of stopping this. It didn't cause any huge problems, but the shift in position meant that a little bit of rain was blowing in, when the side door of the van was open....
I think some sort of "wedge" would stop any such movement in future.... but it's something to look out for when using the Kador strip in high winds
++ on ease and speed of detaching & re-attaching to the awning though
I have a set of stop ends which as it suggests stops the awning moving in the Fig 8 gutter, work very well, very useful when it is windy. 7 squids and free post or £6.65 with code!
https://www.olproshop.com/collections/c ... -end-stops
Or use a length of kador strip longer than the awning and clamp it in place with pound shop spring clamps!Flanners wrote: Tue May 29, 2018 7:14 pm I have a set of stop ends which as it suggests stops the awning moving in the Fig 8 gutter, work very well, very useful when it is windy. 7 squids and free post or £6.65 with code!
**edit** Holy-moly! They're not that big - only about 3 inches long
Mark
- Bongo Brain
- Bongonaut
That's great - thanks for letting us know FlannersFlanners wrote: Tue May 29, 2018 7:14 pm I have a set of stop ends which as it suggests stops the awning moving in the Fig 8 gutter, work very well, very useful when it is windy. 7 squids and free post or £6.65 with code!
- Bongo Brain
- Bongonaut
Another interesting solution - thanks for posting this tooMarkas wrote: Tue May 29, 2018 7:21 pmOr use a length of kador strip longer than the awning and clamp it in place with pound shop spring clamps!Flanners wrote: Tue May 29, 2018 7:14 pm I have a set of stop ends which as it suggests stops the awning moving in the Fig 8 gutter, work very well, very useful when it is windy. 7 squids and free post or £6.65 with code!
**edit** Holy-moly! They're not that big - only about 3 inches long![]()
