Open Fires
Moderator: Ian
Open Fires
I have been asked to clarify the policy on open fires at the Bash. Lickhill Manor's policy is that open fires are not allowed in any circumstances. This includes firepits, braziers and even "raised platform" campfires. The policy was introduced because of the danger of embers settling on awnings and tents.
The only exception is small barbecues which are allowed providing they are off the ground.
Please respect the site rules, they are there for a reason.
- Jillygumbo
Re: Open Fires
Does this also include BBQs (off the ground) that are kept alight after cooking by adding fuel? Might be worth clarifying.
Jillygumbo, Marvin & Lady
Re: Open Fires
Just keep yer sausage to hand Jilly.
Re: Open Fires
Why on earth would you do that? A BBQ is for cooking. Once cooking is over, there's no point in adding fuel........unless you are thinking of having a late sausage.Jillygumbo wrote: Fri Jun 15, 2018 11:53 am Does this also include BBQs (off the ground) that are kept alight after cooking by adding fuel? Might be worth clarifying.
Re: Open Fires
Any time is 'sausage time'.
- Jillygumbo
Re: Open Fires
Some people do this as an excuse to keep a fire going without breaking rules.Ian wrote: Fri Jun 15, 2018 5:58 pmWhy on earth would you do that? A BBQ is for cooking. Once cooking is over, there's no point in adding fuel........unless you are thinking of having a late sausage.Jillygumbo wrote: Fri Jun 15, 2018 11:53 am Does this also include BBQs (off the ground) that are kept alight after cooking by adding fuel? Might be worth clarifying.![]()
Re: Open Fires
I find a fire extinguisher usually solves the problem
Re: Open Fires
A bucket of water is cheaper.
- Jillygumbo
Re: Open Fires
Is the staff going to be armed with one?
Re: Open Fires
A SuperSoaker and assistant dragging a paddling pool full of water might be as effective
- Jillygumbo
Re: Open Fires
Ruca will help with the paddling pool!g8dhe wrote: Tue Jun 19, 2018 8:36 am A SuperSoaker and assistant dragging a paddling pool full of water might be as effective![]()
