Help me translate diagnostic codes (v6 auto gearbox)
pixies
Post by pixies » Wed Apr 24, 2019 12:23 am
Following the various helpful guides on here and online, I have the following:
https://youtu.be/VsA89npUrnQ
I read this as 12 (Throttle position sensor) and 60 (Shift solenoid A)
but the Transmission Codes members-area download says:
Caution: there is no way for the system of flashes to show zero, meaning
code 6 (output speed sensor) and code 60 (shift solenoid A) will be reported
identically!
Anyone here a wizz with the flashes? Any opinions?
Neil.
jimmo62
Re: Help me translate diagnostic codes (v6 auto gearbox)
Post by jimmo62 » Wed Apr 24, 2019 8:53 am
06 is an engine code and 60 is a gearbox code - you access engine codes by using the TEN pin and gearbox codes with the TAT pin - so you can tell which is which from which pin you connected to ground.
jimmo62
Post by jimmo62 » Wed Apr 24, 2019 8:54 am
pixies
Post by pixies » Wed Apr 24, 2019 9:10 am
Thanks Jimmo.
But that link still has '06' under the automatic transmission error codes too.
Post by Ian » Wed Apr 24, 2019 9:30 am
When this has happened in the past problems with the TPS are accompanied by problems in the shift solenoid pack. You can get replacements via www.mazdabongo.com
