Intake Air Temperature Sensor
Hello,
My Bongo is producing an ECU error of P1112 Intake Air Temperature Sensor Circuit Intermittent, so I'm after an Intake Air Temperature Sensor as a first step to fixing.
I'm having trouble locating the sensor, any ideas? My Bongo is a 2002 2.5 Diesel 4WD.
Re: Intake Air Temperature Sensor
Use the Mechanical diagrams site, choose the year / version then under the Electrics option you will find location and part number for the Air intake sensor. http://www.lushprojects.com/bongopartsmk2/
That's a great resource, thanks for sharing.
Could I ask, what is the fault with the vehicle and where / how did you obtain that code?
My Bongo is going into limp mode (flashing hold and glow plug lights). I read the error using this guide [1]. For the error in question, I'm trying the steps suggested here [2] since it's cheaper than a garage visit.teenmal wrote: Wed Jul 31, 2019 1:09 pm Could I ask, what is the fault with the vehicle and where / how did you obtain that code?
[1] http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
[2] https://www.autocodes.com/p1112_mazda.html
I dont think your vehicle will have a IATs,the only air temp sen would probably be the scavenger fan Sensor.
This diagram [1] matches my Bongo, so hopefully it's the correct sensor.rita wrote: Wed Jul 31, 2019 7:15 pm I dont think your vehicle will have a IATs,the only air temp sen would probably be the scavenger fan Sensor.
SENSOR,IN.AIR TEMP
N3A118845 18845 SENSOR,IN.AIR TEMP
And here [2] is the part with matching reference MAZDA: N3A1-18-845 which corresponds visually.
[1] http://www.lushprojects.com/bongopartsm ... o=.html#16
[2] https://www.ebay.co.uk/itm/Intermotor-I ... 3574515083
Sorry,just noticed the age of your bongo.
Bongofamily
- Junior Bongonaut
Hello
I am new to Bongoing, have owned our van for a couple of weeks. It is the same age and model as the OP and has a flashing glow light too. Ran diagnostic check and got several error codes some that seem to make sense and some that don’t. I think I got 14, 10, 20, 11, 12 and 18.
Anyway one of those is for the intake air temperature sensor and I wondered if replacing the part had fixed the problem?
