Exhaust manifold is off! YAY!
Re: Exhaust manifold is off! YAY!
Looks good.
Yep, was hoping to make a start today but when i opened up the bits for the gasket only 4 out of the 8 studs were included so itll be monday now before the others come. In the meantime ill sort the rocker cover leak.
									'96 AWD 2.5 diesel with AFT
						Re: Exhaust manifold is off! UPDATE
Update
Right pretty much back together after replacing lots of new studs etc and fighting to line everything up including that exhaust bracket that comes off the back of the gearbox!
Anyway, I just realised when I went to put the large air intake pipe that runs from the turbo round the back of the engine to the air filter that I had to rip off all the old corrugated heat shielding and havent source any more.
Does anyone know where to get some from and has it a special name as my googling is coming up empty
I just get a large piece from a scrap yard but never tried to buy new, I would imagine it will be available from the car build/ tuning web sites, search heat shield or similar.
A Google search for exhaust heat shield brought up several different types.
Ended up going for this
https://www.ebay.co.uk/itm/Exhaust-Turb ... 2749.l2649 I honestly thought it would be easy to just get some of the same I ended up having to tear off but just cant find it so this will do im sure.
then onto the next thing!
