Tracks cleaned,motors matched and serviced,stuck rollers released, tent washed out,seals cleaned and repaired,bed deck reversed and sectioned etc even cleaned the solar panel of 2 years accumilated seagull crap!
Last jobs today are net repairs,lock switch move and what appears to be dry joint on motor regulator circuit board item D1 then moving lock switch to dash. This last bit I have a query on. I have continuity checked the switch wires back to the roof controller and it would seem that all I need to do is let in new cable to the controller socket. My question is do the switch wires run directly to the unit or is something else attatched en route?
Roof raise time now 28secs to fully up. Was 40secs so very happy that three days of effort has gained that result.
