Removing the rear speakers
Ollymuk
Post by Ollymuk » Mon Aug 03, 2020 1:11 pm
I want to remove the offside rear speaker and take it away from the plastic panel, and reinstall it on the side kitchen panel so it's nearer the rock and roll bed (rather than behind the kitchen cupboard).
However I physically cannot get the speaker out of the panel. Someone told me I need to remove the entire panel and then remove the speaker from behind.
Is that right? That's gonna be a horrible job given that I have kitchen in the way.
Any advice welcome.
Olly
Re: Removing the rear speakers
Post by g8dhe » Mon Aug 03, 2020 1:15 pm
That is correct, the speaker grill and speaker is attached from the rear on plastic spigots spot "welded" down to hold them in place.
Ollymuk
Post by Ollymuk » Mon Aug 03, 2020 1:35 pm
Argh! I've spent too long jammed in to a small space in a hot campervan on even hotter days. Arrghh!
Time to angle grind the panel around the speaker. I'll migrate the entire area.
Bongolia
Post by Bongolia » Mon Aug 03, 2020 2:46 pm
Fraid thats not gonna do it either. The speaker is bolted to a frame that in turn is bolted to the vehicle structure. Why not run another wire to relace that speaker wire from the back of the radio znd leave the old speaker in situ.
Ollymuk
Post by Ollymuk » Mon Aug 03, 2020 2:51 pm
Yeah. I guess that's probably the only solution left.
At the moment I'm drowning in cables and half cut pieces of panelling, saws, and general parts.
I only came out to fit a a shelf 😔
Thanks for the help.
Rickster
Post by Rickster » Mon Aug 03, 2020 6:17 pm
The easy bit is running new speaker wires from the radio, just go over the engine bay and you're done.
If the rear speaker is to be a new one, I would recommend replacing both at the same time, it's relatively straightforward to do, they are a 5 x 7 size, Alpine are cheap for a pair, a little over 20 quid online.
Ollymuk
Post by Ollymuk » Mon Aug 03, 2020 6:35 pm
Rickster wrote: Mon Aug 03, 2020 6:17 pm The easy bit is running new speaker wires from the radio, just go over the engine bay and you're done.
After my experience with the offside, I'm not even going to touch the nearside one. I'd be happy (ish) with mis-matching speakers.
Bongolia
Post by Bongolia » Tue Aug 04, 2020 10:47 am
Ollymuk wrote: Mon Aug 03, 2020 2:51 pm Yeah. I guess that's probably the only solution left.
:D Been there,done that :D
Rickster
Post by Rickster » Tue Aug 04, 2020 4:04 pm
Ollymuk wrote: Mon Aug 03, 2020 6:35 pm
That's fine.
I'm more of a Hi Fi freak if anything, although vehicles will always have crap sound given how metal is the worst material for a speaker enclosure.
The only reason for changing, especially the front speakers, is so it had more treble for the sat nav voice, the old speakers sounded like it was trying to operate in the bath!
Ollymuk
Post by Ollymuk » Fri Aug 07, 2020 2:18 pm
Are the front speakers the same? With the plastic grill being part of the door panel and the speakers bolted in?
Rickster
Post by Rickster » Fri Aug 07, 2020 10:17 pm
No, they are round with three screws holding them to a plastic frame.
The pic below is one of them.
Ollymuk
Post by Ollymuk » Sat Aug 08, 2020 8:50 am
Thank god! Something that should take too long or cost me the earth.
Olly
