Coolant alarm
Coolant alarm
Hi all, I've had my bongo (2000, diesel, 4wd) less than a month and was checking fluids this morning, squeezed a coolant hose, all doors open both front seats up and the haydn coolant alarm went off for 5-10 minutes. Keys not in ignition. I put the key in and turned and heard a second alarm( a beep beep beep sound) Checked the expansion tank and the coolant was showing just above the screw. Topped it up and alarm continued. Tentatively started the engine and the alarm turned off after a few seconds.
I have noticed that the alarm does 1 test beep only when I start the engine and that can last between short pip or 1-2 second beep. Normally a short pip.
Can anyone help me understand what's going on here? Should alarm sound with keys out of ignition?
And i assume it's OK to drive if the expansion tank is full and the alarm isn't going off?
Thanks in advance for your wisdom!
2000, 2.5 Diesel, 4wd, AFT
Re: Coolant alarm
Haydn will likely spot this and reply, but if you Google 'Haydn Alarms' the contact details are there.
Their after sales service is the very best, and I'm certain Haydn and Jo will sort it.
Re: Coolant alarm
Thanks for the reply!
I did email them about the short test beep and haven't receive a reply yet so thought I'd try here. I couldn't find anything with searches on here.
I'll keep looking
Tom
I'll keep looking
Tom
Re: Coolant alarm
Search under the top bar to the left side;
- haydn callow
Re: Coolant alarm
Hi, the alarm should only beep when you turn the ignition on and again when you turn key to start, the only other time you should hear it is when the coolant is low.
New Red antifreeze can cause problems but not what’s happening to you.
Weak coolant, same as above.
Are you sure it’s the coolant alarm that is sounding ? There are loads of other things in a Bongo that beep.
If it is the alarm it sounds as though it’s wired in wrong, it should be connected to ignition, switched live. Yours must be wired to a permanent live....you need to correct this and report back.
Re: Coolant alarm
Thanks for your help, I can see the orange wire going from the expansion tank and it disappears off behind the dash. I'll have a look at the weekend when there's a bit of daylight!
The coolant alarm led lights up when it's going off so I assume it's that.
Tom
Tom
Re: Coolant alarm
Hello, so I went out in the dark - not great for photos. The earth/power wire head off and join to some connectors. I don't know much about wiring but learning.
The red/ black wire goes to a connector that has labels brake and gnd. When I moved one of these connectors the alarm sounded for about a second or two.
The red wire goes to a connector that looks like it might be head unit but not sure. Bottom right of picture.
I'm guessing this is power coming from the leisure battery and that it's the one I need to reconnect to ignition switched power?
I have a multimeter on order - so will try to figure out how to check what's what.
Can anyone tell me what I should check with multi meter?
Thanks again
Thanks again
Re: Coolant alarm
The scotch block connectors are probably the source of your problems, its critical that you use the right size wires for them to work, the standard jap wiring loom wire gauge is too small and hence the usual problem of intermittent connections causing the self-test to bleep each time there is a break in the power/earth connections!
Re: Coolant alarm
Thanks, I'll have a look at those, what would you recommend replacing the scotchloks with?
- haydn callow
Re: Coolant alarm
Crimp connectors or best of all solder,
Your best bet might be to rip the alarm out and refit following the instructions supplied by us.
Failing that check every joint and fix any loose ones.
Re: Coolant alarm
Thanks Haydn - can I find the instructions online- I don't have them in my paperwork?
- haydn callow
Re: Coolant alarm
Contact Jo for a copy, phone number on website, say ‘dad says’
Re: Coolant alarm
Thanks - just an update - I contacted Jo who sent me instructions and advice!
I rewired to the ignition switched 12v as suggested, into the front of the fuse box and included an inline fuse. Also replaced the scotchloks with crimped connectors.
It's all working as it should now so thanks very much for your help!
Re: Coolant alarm
Brilliant.
