Coolant leak; parts guidance
Regadge
Post by Regadge » Tue May 24, 2022 3:39 pm
Hello Bongonauts,
My dear rust-bucket has sprung a leak and I fear a decommissioning is imminent. I have located what I hope is the (only) source and attached pics of culprit. Does anyone know what the pipe is and if it is a simple fix? Passenger side of a '96 Friendee.
Thank you
Re: Coolant leak; parts guidance
Post by g8dhe » Tue May 24, 2022 4:12 pm
Welcome aboard!
Have you looked at the diagrams for all the coolant pipework in the shop section ? see here https://bongoland.co.uk/identifying-your-hose/
Regadge
Post by Regadge » Tue May 24, 2022 6:03 pm
Thanks g8dhe, that's a good start, albeit fairly mind bending :D
Post by Northern Bongolow » Tue May 24, 2022 7:49 pm
Is the pipe that goes to steel then the bottom of the turbo.
Looking at the pipe that goes from just under the bleed pipe, ( top left in pic 1) to the turbo, that looks a bit suspect as it's discoloured .
Regadge
Post by Regadge » Tue May 24, 2022 8:04 pm
Cheers NB. I wish I could answer but I don't know a turbo from a turbot :-k
