Good to know.g8dhe wrote: Sun Jul 03, 2022 9:26 pm Yes those are intended for caravans, where by your charging the battery in the caravan and possibly running the fridge whilst driving. They rely on the length of wiring from front of the car to the caravan to limit the charging current and then handle the fact that when on-site the car is disconnected and the caravan uses its own battery or its own EHU connection. Whilst in principle this is similar to a campervan its NOT identical, hence the relay is not adequately rated for the charging current and often burns out after a while depending on how much the LB is used etc! There are much better options designed for campervans where the relay is much more adequately rated and doesn't have the need to handle the back of the van being disconnected from the the front seats and engine!
At the time when I was doing all my research on trying to figure out what the problem was I do recall coming across threads/articles which advocated the better options you’re talking about.
Something for the future perhaps as I haven't revisited it since I replaced it.
I know that its current function / use is to solely charge the LB when the engine is on. The fridge is only powered on when the inverter is on, so if its off and the engine is on the fridge will not run.
If the both the engine and inverter are on, the component is at its highest usage and Im thinking thats because the LB is being used/charged at the same time.
In an attempt to achieve best efficiency, thats when I turn my fridge on, whilst the engine is running, so that I can preserve the LB for when I need it most.
