Strange Whine Noise 2.0L
BongoLawrence
Post by BongoLawrence » Tue Feb 28, 2023 1:05 pm
For a while now my Bongo has had a strange whine noise. It only happens when it's cold on first start. The first few times you put the revs down it develops this strange whine noise.
https://youtu.be/k4riHfhulos
(for some reason YouTube has marked the video as age restricted, not sure I'm showing that much leg in the video)
I've recently changed both the drive belts and alternator (after the alternator failed). Anyone had anything similar? It's a 2001 2.0L.
Thanks,
Mike
Flanners
Re: Strange Whine Noise 2.0L
Post by Flanners » Wed Mar 15, 2023 12:09 pm
suggest due to cold temperatures and transmission fluid flow rate is much slower....if it is momentary when setting off. Check fluid level and colour.
