I don't know if any one has an idea what could have happened here but I would welcome any suggestions.
When I turned the ignition key this morning nothing happened. Waiting a few moments I tried again, still nothing. On the third try everything was as it should be.
Yes, I did wait a few seconds after the glow plug light went out. I was in park and the handbreak was on.
I have been out and about all day, sometimes leaving the Bongo for two or three hours, it hasn't happened again and it has never happened before.
Lee
emStarting problem
Lee10
Veg_Ian
ircbongo
Probably won't happen again...
Had a similar problem with my Bongo a couple of months ago. Did it once then hasn't done it since. The only thing I did do was move the gear lever into Neutral and back to Park. Don't know for definite if this is what fixed it coz it started next attempt and hasn't done it since, but it seems quite likely that the gear lever wasn't fully in the Park position or the inhibitor switch had a "blond moment".
Hope yours is the same
ircbongo
ircbongo
Lee10
