I checked my coolant level in the header tank before I left work tonight. It had dropped a bit. As there is no leak (as far as I am aware and I looked over all the joints etc during the engine on/bleed process) I guess it has burped a bit more air out of the system. The workshop manual does suggest this will happen and in fact tells you to repeat 4 or 5 times a cycle of 5 mins at 2500rpm followed by 3 mins at idle. It then tells you to stop the engine, let it cool and then check and top up coolant level as required. I reckon I only did 3-4 cycles (I'd had enough of a diesel engine roaring away in the drive as it got dark) so I guess it is quite natural that air will continue to burp out. Temp gauge is looking v healthy, coming up to temp in half the time it took before thermostat change, and staying rock steady at 11.00 oclock.
Thanks again for all the help - I cant imagine having the confidence to try any of this without BF support. Brilliant. Builds my confidence each time I havea go and (with luck and so far) pull it off.
   Pete
       Pete I topped up slowly to max, and haven,t looked back! The level hasn,t dropped a millimetre in 8 months....
