windscreen blower
carvitara
windscreen blower
Hi,i have a 1997 Bongo with the digital heater controls.For some reason the blower will not go onto the windscreen but comes most of the time through the vents...it all used to work perfectly and has only just started with this problem...Any advise would be great...Cheers Mark
BPH80
under the dash just above the foot rest there is the selector controls. one part moves when you select the options on the control panel on the dash. this has a little metal bar that conects to the plastic selector. and can quite easily be knocked out by your foot if banged.
stick your head down there with the heater on and select the heater controls on dash you should see how it works and simply conect the metal bit back.
or possibly a fuse or somthings gone for the selector.
