Just a quick question regarding the timing of the final Lockup gear on a Auto Bongo.. I have spent the morning reading the site and have learned a great deal on the Auto box - so thanks to everyone here! Also realised it can be very expensive for failing to interpret incorrect behaviour
 Mine appears to change up correctly, but when for eg. Cruising at 65 mph running on the torque lockup, if I (quickly) completely remove the throttle position it disengages from torgue lockup and returns to 4th.. Gently restore throttle position and it revs slighty higher for a very short period of time and then returns to torque lockup... ?? All done over the space of a few seconds and not dropping below 60 odd mph
If I gently remove throtte position when in torque lockup at 65 mph and keep at a very low constant it does not change down into 4th? instead it stays in torque lockup.
I have read various searches and have only found of one similar instance ?
I have checked the fluid and it seemed OK, I think I may opt for changing it later today tho..
Can anybody shed any thoughts/ experiences?
Warren
