 Just getting my head around the cooling system Franco
Well there is indeed a problem, but... the comment was more to explain why the flow from the bottom pipe was cool, not hot, rather than the system working correctly.The Great Pretender wrote:So Dannyboy, if the system is made for hotter countries and can cope with anything we can through at it in the uk, why the head problems?
If the hottest part of the engine is where the problem is, its down to a cooling problem, and size here aint important, design is.
 As we have now in the last 4 weeks (perhaps) changed/ switched the {thermostat (old, new, holly with different number of holes) and radiator}, bled the system 12 or so times, with only 3 occasions when the bottom hose warmed up with the new stat in place,  as suggested in the manual, on these occasions, the bongo is stationary and the fans are off. As soon as the fans come on or the vehicle starts to move the flow of air through the radiator cools the water to enough of an extent that the lower hose is cool.
