split relay charge
				Duncan
split relay charge
wheres the best place to tap into the 12volts on/off alternator light.
I have wired to both my batteries from the relay as per instructions, and earthed the correct terminal, its just wiring to the alternator I am struggling with. I have found the plug in the side of the alternator that carries two wires, is it one of them ?
				Veg_Ian
- dandywarhol
As everyone else is suggesting; go with the TEC3M.  It makes the job a piece of cake.
Here's my instructions.
				Duncan
split relay charger
Yep as you said, connecting to the alternator works but leaves the light on slightly, this because the relay is drawing to much current and dropping the 12 volts to 7 volts. Being stubborn and not liking being beat I have added another relay to drive the split relay charger. this relay only draws 40 milliamps on the coil so the voltage does not drop. this relay then drives the contacts on the heftier split relay charger. happy to say it now works. Thanks for the imput.
Cheers Duncan
						Cheers Duncan
thinking of swapping my winter pack to a single + leisure battery too.
just a quick question on split relays ect........after reading corblimeys fitting instructions and got looking for the said item and came a cross this
http://digitalsounddirect.co.uk/shop/pr ... d/907.html
just wondered if anyone had fitted this type before or if it will be ok as i intend to swap all the electricals on to the leisure battery
just came across this too
http://www.volkszone.com/VZi/showthread ... ge=2&pp=10
exuse my ignorance but...........if a normal relay will work from a mk1 or mk2 golf, whats the difference between this and a tec3m?(which i havent been able to source) as this is only a 30 amp and the golf one is a 40 amp
				Mark & Shelly
Hows it going Wayne?
I think the Tec3 relay is a voltage sensing type, so it wont switch untill your main battery has got charged back up to capacity. These also stop the risk of your starter motor trying to draw current through your split charge circuit, which can happen if you wire an ordinary relay trigger to an + ignition/acc feed rather than the charging light(which is more complicated, & according to some sources not recommended for Jap vehicles).
When I did ours I tried to get away with a 30 amp relay, but found with a fairly flat leisure batt. & that 90amp bongo alternater I could blow fuses untill the cows come home.
Now I have a 100amp relay fused at 70amp, which is switched by a time delay relay connected to a convenient + acc feed, has anyone else gone down that route? seems to work a treat.
				Duncan
I also think a time delay relay is a good idea. I still went with just the basic 35 amp split relay charger £10. Like I previously said though the only fault with this is the relay coil draws to much current and drops the 12 volts from the altenator. Because I work with some cleaver lads they provided me with a smaller relay to provide the voltage switch to the main relay. I did it this way because the relay was free and it works
