SCAVENGER FAN
				alldav61
SCAVENGER FAN
HOW DO I CHECK TO SEE IF MY SCAVENGER FAN IS WORKING
						- Peg leg Pete
- dandywarhol
				paul9
Just been testing my scavenger fan,the sensor is a black plug under centre consul,just unplug it, switch ignition on and it should start to work after a few seconds,your heater plug light will probably flash on/off until you plug it back in to the sensor,i didn't need to use a paper clip on mine,so sensor must work opposite way
- dandywarhol
				paul9
- dandywarhol
I thought I'd try the scavanger fan test method - unplugged the sensor wire and the fan DIDN'T come on   ..........I connected the wires with a paperclip and the fan came on - removed the paperclip and the fan stayed on
 ..........I connected the wires with a paperclip and the fan came on - removed the paperclip and the fan stayed on   until I reconnected the terminals to the sensor...................weird things these Bongo electrics
 Pete
       Pete
