And the moral of the story is keep away from the contacts with your spray grease.
Flashing roof warning light
- daveblueozzie
Re: Flashing roof warning light
OK got it sorted i hope, i raised the roof about a foot so i can get to the contacts, gave them a good clean,and must admit a lot of grease came off one of them, lowered the roof ,waited and tried again, PERFECT. so it must have been me being overeager with the silicon grease.
Lost without my Bongo.
Nice easy fix
ScubaBongo
Fixed mine too, using a cut down version of Bongo Boozers solution:
1. Open roof half a meter.
2. Locate the microswitches- you can see them on the underside of the roof panel if you stand on drivers/passangers seat.
3. Loosen the 2 screws in the yellowy-white component of the switch. Push this part towards the black switch. Re-tighten screws.
Done!
Thanks all, another job sorted.
Done!
I see...Like the springy contact at the base of a bulb? Prise it upwards..Better contact?
ScubaBongo
Yeah, same principle.bigdaddycain wrote:I see...Like the springy contact at the base of a bulb? Prise it upwards..Better contact?
Seemed to me that the yellowy-white parts was slotted, so probably was always expected to need 'fine-tuning' at some point. (Black part isn't slotted, and offers very little adjustment, not worth trying to move that unless the adjustment in the other bit isn't sufficient to solve the problem).
Glad it's sorted, the flashing red light on the dashboard was actually really annoying (guess that's the intention!)
- daveblueozzie
My roof light started to flash again and the beeps when i started the engineScubaBongo wrote:Fixed mine too, using a cut down version of Bongo Boozers solution:
Done!![]()
