Re: Temp sensor(s)
Posted: Mon Jul 05, 2010 5:05 pm
Ah - is that a separate sensor?? I thought the coolant sensor gave that signal......................missfixit70 wrote:As you know, I hate to disagree with anyonedandywarhol wrote:AyeNorthern Bongolow wrote:is that the fan switch dandy,that your refering to,does that also control,gbox lock up?but what about the ATF thermostat sensor? provides the ATF oil temp signal 2J on the ECU?
Any idea where the ATF sensor is?
