missfixit70 wrote:Jaws wrote:I always replace oil and filter at the same time for all my vehicles.
Why wouldn't you?
Basically cos it's not necessary, as documented in th Official Mazda Bongo Freindee handbook.
There are four worthwhile theories of oil & filter change interval, and a thousand worthless ones.
Theory I says that the manufacturer states oil and filter change at 10,000 miles, therefore I can do an interim oil change at half that for more protection, and then change the filter at 10,000 miles or so. Advantages: seems like cheap insurance. Disadavantages: None of us know when the filter is blocked, the bypass valve has opened, and filthy boiling goo is destroying our engines from the inside out.
Theory II says that the filter is as important as the oil, as it is the only item in the engine which keeps the oil operating as oil.  There's no point in changing the oil without changing the filter; most engine wear occurs when the filter cannot filter out particles of about 15 microns in size or larger,  that being the dimension of the gap between (some) surfaces in  an oil lubricated engine. So why not just stick to the manufacturers specs, or bring them forward a bit and change both oil and filter at say, 8000 miles? Advantages: seems like cheap insurance, Disadvantages: Over 50,000 miles you'll have changed the oil and filter 6.2 times, instead of 5 times.
Theory  III, used by the US Army, says that with correct filtration,  engine oil life is at least 50,000 miles on diesel trucks, and that no oil will be changed unless lab analysis shows contamination  or a large reduction in additive performance. The filters, shall however, be changed very regularly and oil levels checked daily. Top-ups keep the additive levels in the correct range. Advantages: on 152,000 six litre trucks, oil sampling is cheaper than replacement. Disadavantages: Each Army depot needs to buy a sampling pump, a pencil and a notebook.
Theory IV - don't bother, it makes no difference. (See below *)
Take yer pick.  What none of us do, me included,  is to save the money we spend on needless oil changes, and instead send a sample off for analysis. It's easier to change the oil.
In the case of the Bongo, though, sample analysis would also pick up coolant contamination.  Any takers?
http://www.theoillab.co.uk/
* Consumer Reports, with one of the most widely respected product testing laboratories in the world has just released the results of an extensive test on oil brands and oil changes, as well as other issues regarding car care. In the process, the test demolished much of the conventional wisdom regarding car lubrication. The two most surprising results: the frequency with which oil is changed doesn't matter after the first few oil changes on a new engine, and the type or brand of oil used can not be shown to make any difference.
The testers placed freshly rebuilt engines in 75 New York taxis and then ran them for nearly two years, with each cab racking up 60,000 miles, placing different brands and weights in different cars and changing the oil at 3,000 miles in half the cars and 6,000 in the other half. At the conclusion of the test period, the engines were torn down, measured and inspected. The conclusions: Regardless of brand of oil or weight, no measurable differences could be observed in engine wear. Furthermore, there was no difference among cars which had oil changed at the shorter or longer interval.
Does this have any bearing on the enthusiast's car, which is given almost the opposite usage stored for long periods of time then started and driven for short distances? The tests suggested that our type of usage would build up sludge and varnish, indicating that an annual or semi-annual oil change is a good idea regardless of how much mileage the car is driven. But there is little indication that the brand or weight needs to be given serious consideration, and synthetic oil has no discernible advantage over the old stand-bys. More information on the tests and results can be obtained from Consumers Union or the July issue of Consumer Reports available at most libraries.
Source: British Car Magazine, October-November 1996
