Oil filtercwas done about 1000 mikes ago. How can a filter make such a noise?Northern Bongolow wrote:did you change the oil filter, it sounds like a filter to me.
Strange, Uneven Ticking Sound
Mark Elvin
- Tribal Elder
Re: Strange, Uneven Ticking Sound
it could be the internal valve ticking if blocking or faulty.
https://www.google.co.uk/search?q=oil+f ... B195%3B216
https://www.google.co.uk/search?q=oil+f ... B750%3B514.
https://www.google.co.uk/search?q=oil+f ... B580%3B415
Mark Elvin
- Tribal Elder
I've ordered a Bosch filter just in case that cures it.
wheres the fingers crossed smilie
Mark Elvin
- Tribal Elder
Stethoscope has arrived so guess what I'll be doing tonight......
good luck doctor
Mark Elvin
- Tribal Elder
So then.......
the noise is coming from the too end, rear cylinder.
Hooing it's a tappet that needs adjusting, can't see it being a broken tappet as she's running sweetly.
Gasket and bolt seals on order. May order a tappet too in case ones damaged
Mark Elvin
- Tribal Elder
Finally got to the bottom of it
Popped the rocker cover off & not only were all of the rockers really lose (all over 1mm), but one of the rockers had slipped off the valve because it was so lose. This had it badly damaged the fork that prevents it slipping off the valve, so I've ordered a couple so I have a spare once I repair.
good job doctor, sounds like you caught it just in time.
Mark Elvin
- Tribal Elder
New rocker fitted, valves all adjusted & all is well again, can't believe the difference in having the rocket clearances set correctly makes to the noise levels, way more than on the old BL A-series lumps.
Some of the clearances were actually nearly 4mm!!! No wonder one of the rockers had slipped of the valve stem, the recess to locate the stem is only 2.6mm, I'm lucky more didn't go the same way.
