Pinhole Leak
Mountain
Re: Pinhole Leak
Post by Mountain » Fri Apr 16, 2010 9:39 pm
Dabs wrote:Just a quick question to Techies!!
As you know there are many "shaped" hoses on a Bongo cooling system and I realise that ideally you should always replace any if possible with original Mazda/Ford parts.Preferably NEW ones!
My question is this:-
Is it wise to replace any of the hoses with non Mazda parts ie would it cause harm to replace a shaped hose with a piece of straight hose.it may sound a daft question but in the future we may have to start to make do and mend repairs just to keep these great vehicles on the road!
Any comments welcomed!
I've been thinking along similar lines! Aside from the main shaped hoses, couldn't the smaller heater hoses be replaced with good quality hose of the correct diametre? I don't see why not.
having eventually got to mazda to pick up my stat and hose,
picked mine up today :)
dreamwarrioruk
Re: Pinhole Leak
Post by dreamwarrioruk » Fri Apr 16, 2010 11:36 pm
i know you did cause neil told me
mike, jo and emma
Mountain
Re: Pinhole Leak
Post by Mountain » Sat Apr 17, 2010 3:49 pm
You couldn't make it up....3rd leak this week :shock:
Another pinhole leak. This time the short length of hose that connects the steel heater pipes at the rear of the passenger seat.
These heater pipes are getting replaced with decent quality silicone hose. 16mm isn't it?
Re: Pinhole Leak
Post by missfixit70 » Sat Apr 17, 2010 3:54 pm
It's what I keep saying, they're all the same age, once one goes, expect the rest to follow suit, especially if you've had an overheat. Personally I'd go for a full set of Mazda hoses rather than try & make up my own from lengths of silicone, especially with the issues several have had with weeping from the silicone hose joints in extreme cold, I'd go for proper constant pressure clips if you go silicone.
Mountain
Re: Pinhole Leak
Post by Mountain » Sat Apr 17, 2010 4:42 pm
61-213 is just a straight length of hose though.
Just making a list of part numbers for my phonecall to Mazda tomorrow.....
The 2 rear heater ones are pretty new as it's been bypassed.
The half a swastika shaped top rad one is replaced.
The top rad to header is replaced.
15-261 from the stat already replaced.
Already have 61-214.
Already have 15-186.
Bleed pipe replaced.
So I make that 7 either done already or I have already.
So, 2 front heater and the straight part with the latest pinhole.
The crazy bent one to the rear heater too 61-213.
Bottom large bore 15-185 and 15-186.
Bottom header hose 15-188.
I make that another 7.
So I'm 3 short :?
Re: Pinhole Leak
Post by missfixit70 » Sat Apr 17, 2010 6:05 pm
Complete list of all the Bongo hoses
Main cooling system - http://www.lushprojects.com/bongopartsm ... mgno=.html
15-261 - bypass/recirc into top of thermostat
15-381 - bleed hose
15-186 - top hose/engine outlet to large metal pipe drivers side
15-183 - Large metal pipe drivers side to top of rad (inlet)
15-184 - bottom of rad/outlet passenger side to large metal pipe passy side
15-185 - passy side large metal pipe to bottom of thermostat
15-227 - top of rad to header/expansion tank
15-188 - expansion/header tank to heater return pipe
Most of front & rear heater system - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-211 - drivers side heater pipe to front heater matrix
61-212 - front heater matrix to heater return pipe
61-214 - heater return pipe to thermostat
61-213 - outlet over starter on engine, drivers side to heater pipe
61-211A - drivers side heater supply pipe to rear heater matrix
Rear heater return - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-212C - rear heater matrix to return pipe behind engine
Another rear heater return - http://www.lushprojects.com/bongopartsm ... 1of02.html
61-213A - rear heater return pipe connector behind turbo under passy seat
Two turbo cooling hoses - http://www.lushprojects.com/bongopartsm ... mgno=.html
13-539A &
13-546 - turbo suppply & return hoses
Makes 17 by my count. I think it's all right, let me know if there're any errors, off to depressurise my brain now.
Anybody deletes this post will be killed - not doing all that again :roll:
Mountain
Re: Pinhole Leak
Post by Mountain » Sat Apr 17, 2010 6:42 pm
:D :D
Cheers!
Turbo hoses done already, including the top steel one that had another pinprick hole in it!
I can't afford the steel ones yet.....in fact I can't afford the rubber ones either :cry:
I'm hedging my bets, but I'd rather get the rubber hoses replaced asap as they are all springing leaks.
Next will be the bottom two main steel ones.
In an ideal world it would be a case of replacing the job lot....but!
The pain is the coolant top up and that bleeding every time. I have to get 2 hoses changed this week so it may as well be seven.
Well, it will probably be next week by the time they arrive :(
You've Been Bongod
Re: Pinhole Leak
Post by You've Been Bongod » Sat Apr 17, 2010 7:31 pm
i will check my pipes and maybe buy a few spare pipes just to be on the safe side
Last edited by You've Been Bongod on Sat Apr 17, 2010 7:54 pm, edited 1 time in total.
Mountain
Re: Pinhole Leak
Post by Mountain » Sat Apr 17, 2010 7:37 pm
Ooops!
Sorry for completely hijacking the thread....but I'm on my 3rd pinhole leak this week :cry:
You've Been Bongod
Re: Pinhole Leak
Post by You've Been Bongod » Sat Apr 17, 2010 7:39 pm
Mountain wrote:Ooops!
:shock: :shock: :shock: how many
if you need any hoses contact ian taylor on 01630 656006 tell him carl recomended him
Mountain
Re: Pinhole Leak
Post by Mountain » Sat Apr 17, 2010 7:43 pm
OK. Does he keep a good stock?
I know I'll be waiting a week with Mazda.
Mountain
Re: Pinhole Leak
Post by Mountain » Mon Apr 19, 2010 4:28 pm
missfixit70 wrote:What you've got to bear in mind also is that if you are running it with a leak (other than the danger of complete hose failure), is it holding sufficient pressure in the cooling system? If it's open to atmosphere it may well be running hotter & you could be in danger of creating airlocks if it sucks air back in as it cools?
This is a good point, as it's exactly what's happened to me.
Each pinhole leak has resulted in the 'cold heater'. I now know that this means 'airlock'. Obviously any pinhole leak will suck in air as the coolant cools down and contracts.
So each bandaged pinhole leak requires a re-bleeding. 3 times this week for me...well 4th today in my lunch hour at work.....I have almost lost the will to live :(
I have a suspicion that although these temporary fixes keep the coolant in, they perhaps do not keep the air out. Water tight is not necessarily airtight.
Meanwhile, the bandage and bleed is the only way I can get to work until the offending hoses arrive. :(
Dabs
Re: Pinhole Leak
Post by Dabs » Mon Apr 19, 2010 5:06 pm
I supplemented the amalgamation hose tape with glue that was water and heat resistant to ensure I got a good seal with the repair,its holding up well until I can get hold of a new hose!
Dabs :D
Mountain
Re: Pinhole Leak
Post by Mountain » Mon Apr 19, 2010 8:27 pm
Yeah it does need something extra :shock:
One of mine held fine the other seemed to stop the leak but let air in.......unless there is another leak :(
Have just this minute finished replacing the 2 with holes in. I just can't risk it as I need to get to work....to pay for all these hoses :roll: .
BTW who puts those hose clips on at the most ridiculous angle :evil: ? I now have a shredded forearm!
All other hoses are on order from a variety of sources. When they have all arrived the guy at the garage is going to change all the rest, change the stat for the genuine Mazda one I have and re-bleed.
It's got to the point where dropping it off and picking it up the next day may well save me from a heart attack and possibly a divorce.
I've had some dodgy vehicles in my time but nothing has ever cost this much or caused me so much stress :cry:
Surely when all hoses are replaced it's got to be fine :|
Low coolant alarm also due to arrive.
randombit
Re: Pinhole Leak
Post by randombit » Wed Apr 21, 2010 3:45 pm
Hi all, we have just sprung a leak, seems to be the same as the one at the start of this thread, 61-214, can't seem to find where to buy it tho.
any help appreciated not sure if I am just too stressed and can't see it. these things don't help when your trying to quit smoking!!!
also does this mean that we need to have the system bled?
