Driver+Passengers wrote:If the pipe is blanked, there will be no further crud deposited within it, as there will be no more dirty air going through it.M 80NGO wrote:Ok some great info on this post and i've read it all with great interest, just 2 things that puzzle me :
1) surely the pipe that's being blanked will fill with crud again bearing in mind that the crud seen in the pics could be 16 years worth of crud ?
If you choose not to blank it, then you may still want to take the manifold and EGR pipe off to inspect, clean and refit - on the assumption that it's not going to be spotless in there, particularly if you're getting the characteristic weeping gunge around the gaskets. Blanking is easier because you don't have to remove and clean, but I'd argue that you'd probably want to remove and clean the inlet manifold and elbow. At which point, it's 6 and two 3s whether you blank or refit. Cleaning out and replacing gaskets is going to be a good job in itself, it's just you may have to do it again a few years down the line.M 80NGO wrote:2) why is it not just as easy to take it all off clean it all out and then refit complete with EGR as mazda intended ?
I get the impression that "as Mazda intended" may be subject to differing opinions. Japan's strict(er) emissions regs require the EGR to reduce nox, and I've read at least one post where the author reckons it 'looks like an afterthought'.
We may be biased towards blanking due to the collective reports that (crud-wise) it "does more harm than good", performance seems better after blanking, it's easy to blank, etc... It is clear, though, that this should not be the final answer.
It doesn't seem like a big deal to include cleaning out and resealing it all into a service regime.
That's what I reckon, anyway. I blanked it because it felt like the right thing to do - who knows?!
Makes perfect sence to me
