bongo speed pulse
bongo speed pulse
hi every one please could anyone help me i am currently in the process of fitting a in dash sat nav unit and cant find the speed pulse has anyone ever installed one or can you tell me the wire location and colour thanks
- dreamwarrioruk
The speed pulse is a very high impedance source and some sat-navs have
been known to drag this down sufficiently to degrade the signal to the
speedo and stop it working, this is more prevelent if you have a converter
chip fitted.
Unless you spend most of your time travelling through long tunnels, it's
best left unconnected, you won't miss it.
chip fitted.
speed pulse
thanks guys for the very fast reply i will try these solutions at the weekend and post my results thanks again everyone
Just about every car I've tested (with various GPS's) show 10% more speed then you're actually doing. I guess the manufacturers go for the cautious approach to not getting their customers in the slammer.
One exception was an Audi S2 - it did exactly what it said it was doing. Another was a Ferrari. I suspect the performance cars are more likely to give accurate reporting - to make you think you're going faster than you are in your escort/othercar...
On my bongo and the old one - 77 on the dial was 70 on the road.
- alphabetter
Remember the MOT requirement is that the speedo reads up to 10% over actual speed, but is not allowed to read under the actual speed. Therefore the designer will almost certainly set the speedo to read a nominal 5% over with a 5% tolerance.
I would agree that performance cars are more likely to be set closer to actual.
- dandywarhol
With modern production techniques it's not that difficult to produce a
speedometer which is practically accurate to 100%. I don't think that
vehicle manufacturers would except an instrument which could be up
to 10 mph fast at 100 mph.
You might notice that most who complain have a constant discrepancy
over the whole range between 5 and 8 mph, and as pippin suggested
these are mostly found on vehicles which have had the speedo face
plate changed.
This is usually caused when the face plate is changed and the needle
has not been set against the lower stop correctly. If you simply replace
the needle against the stop without any tension, it will always read fast
by a constant value.
plate changed.
- alphabetter
Quite right - you learn a new thing every day!dandywarhol wrote:Speedo isn't an MOT requirement - only a constructions and use requirement.............
Probably true, but as an engineer I would always design to the mid-point of any tolerances specified unless someone told me to do otherwise!grumpo wrote:it's not that difficult to produce a
- dandywarhol
and switch on the "ignition" key first.grumpo wrote:With modern production techniques it's not that difficult to produce a
plate changed.
anyone noticed how fast these Bongos go in reverse???35 mph on mine so far
