just to amke sure before i end up with any more bits
my key stuck in ignition avgain - will not budge
i have removed the steering wheel then i assume i just need to slide the indicator bits up and then the ignition bits
is it the whole part that you repl;ace or just part of it?
are these generic or where do you get them - any idea of costs
cheers
ignition
yep been down them before
it stuck once before and i managed to get some lubricant down the key and jiggle for 10 mins but this time no joy
i assume the barrel is just full of gunge or has a burr or something
it's ok today as i had stopped at home but last thing i want is to be on hols and it sticks
will have a play with it when i get it off
Karen
Until you sort it, could you not use the spare key for the door and just leave the other one in the ignition, draping a jumper or something that looks like you dumped it there over the whole steering wheel / ignition lock area but which hides the key. Not perfect but I'd be fairly relaxed about that
ok
steering wheel is off
cant get the indicators off - i have removed the clip
do you remove the yellow front bit or ?
dont want to just yank it
however i turned the key and it popped straight out sodo i squirt the lubricant in again and also from the top - i can see the locking mech that moves when i use the key and pop it to gether again or should i replace the lock
I can understand your concern with leaving the key in karen, my bongo suffered this problem once, ( a few years ago now) it turned out that my key was ever so slightly bent,it was hardly noticeable actually... I remedied the situation by wrapping some masking tape around the jaws of a pair of pliers, then very gently "massaged" the key back into shape, gently, and slowly!... Ive not had a problem since (touchwood)
When it was stuck it wasn,t neccessary to dismantle anything to free the key,i simply switched on the engine,moved the gear selector up and down a few times,switched back off, applied some forward pressure on to the gear selector with my left elbow, and jiggled the key out,at the same time.
No probs since i straightened the key! Bear in mind, the key only had a very slight kink in it... Good luck
