Does not start easilly then the smoke
mr and mrs pips
Post by mr and mrs pips » Thu Apr 26, 2007 8:12 pm
The van has started to refuse to start first time once the glow plug indicator goes out.
Encouragement by pressing the accelorator then a puff of dark smoke and away
anyone know what is causing this ?
The van has been a little juddery on starting the last few weeks just thought it was from lack of milage.
Please advise
Mrs Pips
paul9
Post by paul9 » Thu Apr 26, 2007 8:15 pm
sounds like a heater plug is down,could be more than one so probably best change them all if any are suspect.
Post by francophile1947 » Thu Apr 26, 2007 9:10 pm
Does indeed sound like faulty glow plug.
ebygum32
Post by ebygum32 » Thu Apr 26, 2007 9:42 pm
That be my first choice too and sooner the better to get them changed as it starts to mess with the starter motor and other bits then before you know it you need new starter motor new battery etc so for £40ish from mazdabongo.com ( who will advise you on the correct size ) it is a must and fitting them is easy enough lots of info on hear about it and not so long ago
mr and mrs pips
Smoke n stuff
Post by mr and mrs pips » Sun Apr 29, 2007 7:59 pm
Thanks for the advise
Tools out going in........
Post by mikeonb4c » Sun Apr 29, 2007 10:10 pm
And whatever you do Pips, remember -
You will need to maintain a speed of 215 knots at exactly 60ft
if your tool is to go in and take those plugs out.
Any higher and your tool will bounce straight over the target
mr and mrs pips
Post by mr and mrs pips » Tue May 01, 2007 2:10 pm
mikeonb4c wrote:And whatever you do Pips, remember -
Plugs away....... :lol:
Post by mikeonb4c » Tue May 01, 2007 3:10 pm
Eggsellent Masterspy, Eggsellant
