Clunk when moving from P to D
Have searched posts, a little feebly I admit, am loking for the cause of the clunk when I engage D in auto box, feels (and sounds) like take up in worn UJ, not play when I get underneath and wiggle drives, anything likely? Its a 2 WD Bongo
- dandywarhol
- dandywarhol
Hi Swifty, if you are referring to shifting from park to drive, then could i ask if you have securely applied the handbrake on level ground before initially selecting park?
If the bongo is allowed to roll a fraction or so of an inch after park is selected, then the "slack" in the drivetrain is taken up, which would result in a bit of resistance, or a clunk when drive is selected.
My driveway isn't billiard table smooth,so when i,m ready to park up for the night i engage neutral,then come off the footbrake to let the bongo find its own settling place, then apply the handbrake firmly, then lastly engage park.You will discover that if you employ this method, then, the transition from park to drive is smooth as silk
Your'e too kind mike
I,m just sad enough to handle my bongo with kid gloves
Many a lengthy detour i have traversed in the past to avoid a freshly re-surfaced road... (those cheap council stone chip jobbies)
The family have in the past said they feel like mrs buckets next door neighbour in "keeping up appearences" when handling her prize china
The only similarity with that show that i can draw is my victor meldrew traits...
The thing is BigD you are absolutely right in your approach, and the evidence is your Bongo. Speed bumps, potholes, stone chipped roads etc do I believe make a real difference in rate of decline. I think (but dont know) that Japan has v good roads (the Japs would!) and dear old Bongo must be offended at what it meets in the UK (join the club Big B!)
Mike
Mike
