Do you think this is probably the problem I have (albeit that it is 'presenting' with different symptoms). I'm sure its quite fixable, but I could do without ANOTHER job to do right now!!! If the above advice is what I have to use, how easy is it getting the door panel off (is sticky black gunk likely to be encountered?).If it clicked I would think it more likely that the worm gear inside has slipped. I have fixed this on both my mirrors now, so if it is not wiring what you have to do is remove the mirror (door panel off undo bol;ts from inside, prise off the cover outside). When you have the mirror on your kitchen table (or workbench if you're posh) carefully remove the motor/ gearbox mechanism and you will probably find that the worm gear has moved along it's shaft to the point where it wil only 'catch' the spur gear if it starts at the right point. I think it is probably caused by people 'helpfully' folding your mirrors for you manually.. You should thgen be able to push the gear back so that it is halfway over the spur gear, blow out all the cobwebs and put it all back together again.
I cant blame the Bongo. A whle back, when practising reversing into the drive with the trailer (forget it!!!) I got out of line and snagged the mirror a lilac branch, obliging it to snap full forward. It has seemed a bit iffy since then.
Grateful for any advice chums & thanks
Mike O'Williteverend
